Results 1 to 6 of 6
Thread: Rear wash jet
    Glad im Back -D
    cameron's Avatar
    Jul 2008
    Oldham, Lancashire
    983
    Rear wash jet
    The rear wash jet on the old bus is playing up
    I get one small squirt of water then nothing, let the button go, wait a couple of seconds press again and i get another little squirt.
    Theres plenty of water in the bottle, the pump works good and all the hoses are connected, theres no pools of water under the boot boards either.
    Any ideas guys ?
    Cheers
    Lee
    Nov 2006
    planet earth
    14
    IIRC there is a little non return valve on Drivers side, under the floor panel (the little one behind wheel arch), disconect, give it a good clean, check its working, and blow down pipe and check it sqirts onto rear window. Also worth holding pipe into magarine tub or similar, and get someone to check its pushing water up to valve ok.
    HTH
    Ben
  3. The Following User Says Thank You to cookie For This Useful Post:
    cameron (Wednesday 10th December 2008)
  4. #3
    Niles's Avatar
    Jan 2006
    On the Verge
    470
    rear window washer has its own pump hiding in the washer bottle under the bonnet. Mines snuffed it & I can't be arsed to find it. lol
  5. The Following User Says Thank You to Niles For This Useful Post:
  6. #4
    New Identity
    Dangerous Dave's Avatar
    Dec 2006
    West Midlands
    2,491
    My rear wash pump had broken, the outlet nozzle had snapped off, so when I filled up the water tank, it all leaked out LOL. I had a spare pump from a 940, so I swapped the nozzles. Been fine ever since. You have to look under the front bumper to find this pump, its attached to the chassis away from the water tank.
  7. The Following User Says Thank You to Dangerous Dave For This Useful Post:
  8. #5
    Member
    big fan volvo's Avatar
    Jul 2008
    0
    there is another non return valve at rear in quarterlight area, worth checking that one as well
  9. #6
    Feb 2005
    Somewhere in the south
    36
    a good way to check is to get the small film cylinder type thing in the rear right floor panel (to the right of the spare wheel /seven seat job - open this up first then lift up the right floor flap),
    disconnect the hose that leads up to the rear window from the cylinder and connect a small bit of spare hose to it,
    then squirt the rear washer. If this doesnt work then , then the pump is to blame. If the hose is disconnected then reconnect and try...... If then it desnt work , new hose from cylinder up d pillar and round the roof an into the tailgate.....
    A 2001 Buell X1 Lightning now in sunny Tenerife and a Santa Cruz Superlight..yes I will get on it!
    Looking for a Honda Hornet CB600FS (fairing one in Blue) for the UK
  10. The Following User Says Thank You to Babybadger For This Useful Post:
