Has any ever experianced a rattly front head rest?! my driver side one rattles over most bumps and is really quite annoying!! It seems to be loose where the two headrest legs fit into the seat. I've tried a bit of tape on here but it wears out!
Any ideas?!
The gremlins also seem to have snuck into the car too... every now and then after you start the car, when you would expect all the dash warning lights to go out, a random combination of Engin Management, ABS & STC stay on... although there is never a fault code behind them! stopping and restarting sometimes works but othertimes it will put on a different combination! Interestingly the ABS & STC don't work when the lights are on (which you would expect with a normal fault).
Another starting problem is that sometimes the car will turn and turn and turn and turn and turn (you get the idea!) and not fire. Try again and goes first time.
I cannot fathem this out, but am wondering is a knackered ignition barrel would be the cause of both these starting woes? I can't see any other obvious faults, car is in good condition and well maintained.
Any thought happily recieved!
Thanks all
