Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: throttle body
    D'Management
    Chad's Avatar
    Jul 2008
    Birmingham
    837
    throttle body
    hi people, ive heard and read about people putting larger throttle housings on.
    i just cant remember where, anyone shed any light??????
    thanks
    Chad
    V70R, Saffron, RICA340
    Independent Volvo Specialist
    RICA Authorised Distributor (www.rica-uk.com)
    Shark Performance Authorised Distributor (http://www.sharkperformance.co.uk/)
    www.grnmotors.co.uk (site under construction)
    info@grnmotors.co.uk
    Jul 2008
    Edinburgh
    411
    Quote Originally Posted by Chad View Post
    thanks
    Chad
    I was reading some threads about this on VS the other day and I think some people put the TB from a 960 or 850 NA on.. I think its only a worthwhile upgrade if you are sticking a larger turbo on it.. as it stands I don't think the standard TB is much of a restriction and helps spool up on a standard set up.. could be wrong though - just going by what I read .
    here's a link:
    http://volvospeed.com/vs_forum/index...throttle++body
    guide on removing TB:
    http://volvospeed.com/Mods/throttlebody.htm
    HTH
    1998 BMW Z3 2.8 Roadster
    D'Management
    Chad's Avatar
    Jul 2008
    Birmingham
    837
    thanks pangster., me check it out
    Jul 2008
    Edinburgh
    411
    no problem!
  5. #5
    D'Management
    Chad's Avatar
    Jul 2008
    Birmingham
    837
    also, is it only worth while if changing to a bigger turbo?????
    cause im planning on putting a 19t in soon, but im running a 18t at the moment???
  6. #6
    Alan M's Avatar
    Jul 2008
    Midlands
    46
    The man to speak to about this is Tim Williams. A very knowledgable chappy and I think he sells larger Throttle bodies too.
  7. The Following User Says Thank You to Alan M For This Useful Post:
    Tim Williams (Sunday 2nd November 2008)
  8. #7
    D'Management
    Chad's Avatar
    Jul 2008
    Birmingham
    837
    thanks alan, i'll try send him a pm
  9. #8
    Alan M's Avatar
    Jul 2008
    Midlands
    46
    It might be better to over on the T5D5 forums.
  10. #9
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    barnsley s.yorkshire
    2,138
    Ive only heard very good things about tim williams and been told hes one of the best i will be dealing with him in the future my self i would deff give tim a try
  11. The Following User Says Thank You to t5 pete For This Useful Post:
  12. #10
    RT MECHANICS's Avatar
    Mar 2005
    Hampshire
    137
    A larger throttle body will only help you if you have a larger turbo the standard 850 TB is not that small but if you do get a bigger one make sure you get proof that i makes a difference
    Dont forget there is a hugh amount you can do before you need to change it cams etc etc
    Russ
    LOOK at our project :
    http://www.vpcuk.org/forums/showthread.php?t=16301
    591 BHP 524 Ftlbs torque so far
    The Most Powerful T5 in the UK
  13. #11
    Sep 2006
    28
    i'm sure there's quite a few people who know that Tim has done a lot of work on my car. i have mostly been there when he's done something to my car and i can honestly say his attention to detail and his knowledge is mindblowing.
    the big difference for me though, is that if there's something he doesn't know, he won't blag it, he'll be truthful and tell me what he does actually know about the subject which means you can make an informed choice on the matter. small point but for me a very important one.
    i have one of his throttle bodies as well. i have no idea how it will perform on anyone elses car. what i can say is that at marham in april i had a session on track without it, on the next session the only change made was the throttle body.
    i noticed a difference as soon as we were getting ushered out of the pit lane. just seemed to have much more go in the 2 to 3.5k rpm range. didn't notice any difference at the top of the rev range.
  14. The Following User Says Thank You to irf For This Useful Post:
  15. #12
    S70T5Chris's Avatar
    Mar 2005
    Dull Southampton!
    1,124
    Hi Chad
    I have had a TB from Tim fitted to my S70. I was looking at fitting a larger TB as part of a load of other work at the same time. After speaking with Tim I decided to go with one of his TB's over a 960 TB (which seems to be a popular option). The reasons being, from what I hear not only from Tim but others with experience too, is that a 960 TB is too big, and it almost turns the accelerator pedal into a switch ie, all or nothing. Tims TB is standard TB that has been "bored out" by several MM. By trial and error he has come up with the perfect solution. Granted I had my TB fitted at the same time as a few other bits, still a 16t tho. In my experience, it makes the throttle response so much more responsive. There is no need to plant the pedal to get the car to move, yet the power is still very controllable.
    I don't hold with the fact that it's only worth it if you fit a bigger turbo, i am still running a 16t. In terms of actual performance gain? Dunno!? But in terms of drivability, it's an excellent mod.
  16. The Following User Says Thank You to S70T5Chris For This Useful Post:
  17. #13
    Jul 2005
    35
    On the throttle body aspect, i like irf have one of tims modified ones, i believe/am positive it helps pick up as irf says around the 2k mark, makes the car feel almost n/a (we have completely diffferent ecu maps)...this throttle body is not from a 960 or anything else but the standard T5 ...i know of two very knowledgable volvo peeps that had the 960 T.B's and have changed to tim's special...We will be performing a test at powerstation on the 22nd so let it be judged from there on...(get your orders in peeps)...
  18. The Following User Says Thank You to volvolised For This Useful Post:
  19. #14
    S70T5Chris's Avatar
    Mar 2005
    Dull Southampton!
    1,124
    Quote Originally Posted by RT MECHANICS View Post
    Russ
    Hi Russ
    Interesting topic I think. Just a couple of questions...
    What makes you say that a larger TB is only a benefit if you have a larger turbo? Have you done some testing on TB's on cars running different turbos? What do you mean by larger turbo? 19t, or beyond ie, Garret?
    I'm still using a 16t, and the difference to how the car drives is like night and day. Granted I had a few other bits done at the same time! I think on the dyno day there is a car that we can do a before and after run on, which will be good. But i'm not sure that a power run gives the whole story, it's how the car actually drives that makes all the difference.
    And on the subject of cams (just for my future reference!!), which cams do you run in the peril? I know a lot of people use NA 20v cams, supposidly to give a better top end. But I saw in one of your previous threads that you lost HP using them. So what's your thoughts on the best cams to go for? Should I want to at a later date!!
    thanks for your input mate.
    Chris
  20. The Following User Says Thank You to S70T5Chris For This Useful Post:
  21. #15
    D'Management
    Chad's Avatar
    Jul 2008
    Birmingham
    837
    i shall try tim on t5d5, any ideas on price???? might give it a go and see hows it goes. until you personally try, cant really say as everyones cars are setup differently.
    thanks guys
  22. #16
    Trader
    Aug 2005
    coalville
    68
    I don't think there is much I need to add to this thread as to me the proof of the pudding is in the eating... 7 fitted and seven very happy customer. I don't expect any peak HP gains on a standard car, on a modified one higher boost can be sustained to the red line. The main point of it is to improve drivability without sacrificing throttle control.
    Russ if you have some criticism of the one I was asked to post down to you please do say.
  23. The Following User Says Thank You to Tim Williams For This Useful Post:
    RT MECHANICS (Monday 3rd November 2008)
  24. #17
    D'Management
    Chad's Avatar
    Jul 2008
    Birmingham
    837
    Mr Tim Williams, you have a PM .......
  25. #18
    Mar 2005
    Hampshire
    137
    Quote Originally Posted by Tim Williams View Post
    Hi Tim
    Thanks for the reply
    Instead of taking it as a criticism why not take it as just my thought on the subject ? I maybe wrong
    I have never changed a customers TB only my own one to a 960 TB but my car had so many changes from a stage one as it was i cannot answer what difference it made
    To be honest i did not look at the one you sent for chris's car so cannot comment and did not drive the car with it fitted .
    Its a shame that someone who is really into the volvo world takes so badly when someone else has an opinion. I have no problem with you at all i even tried to get you a refund on something if you remember
    We all all friends here just love the same make of car
    Russ
  26. The Following User Says Thank You to RT MECHANICS For This Useful Post:
    pangster (Monday 3rd November 2008)
  27. #19
    Mar 2005
    Hampshire
    137
    Quote Originally Posted by S70T5Chris View Post
    Hi Russ
    Chris
    Hi Chris
    Have a look at what i put for Tim i maybe wrong its just an opinion i really ment that there is lots of other thngs you can do to improve the car
    As for cams i am still testing different ideas as the the R&D continues ;-)
    Russ
  28. #20
    Trader
    Aug 2005
    coalville
    68
    I didn't take it as criticism, that just how your post read.
    I don't take it badly when others have opinions, that's why I spend over 3 hours a day on the phone talking and listening to others.
    I have no problem with you either, it's just my Northern ways I guess, I find it a little rude when asking a question to only be answered with a Smiley thought as to me that is of no use at all.
    As I have said in an email to you before thank you for trying to get me my remaining unfunded money back but it seems that even with the Pay pal transaction number your supplier could not sort it out so I will not pursue it any further as they as based outside the UK.
    This is not a dig a snipe or a go at you Russ but I am genuinely interested in your 10BHP loss with using N/A cams over your custom ones. I know N/A cams are far from the best for peak HP as that is far from what they were intended for but I would be interested to see the graphs you got when changing to them over your own if you had made no other engine mods between the two runs.
    Tim
