Is removing the ABS ECU from my 850 as easy as the Haynes manual says? Disconnect the wiring & remove the 3 bolts securing the ECU, is it that simple?
Niles (Friday 31st October 2008)
Thanks, so its just a case of remake the solders? My abs lite comes on when i press the 'loud' pedal, just tippy toeing around & the light stays out.
Unplug the multi pin scart like connector and also the power supply.
There are four bolts and you will need a E5 torx sockets (1/4 inch drive) to get them off. Do not be tempted to use anything else to remove them as you'll have an awful job with a stripped head particularly for the 2 bolts you can't see - its all done by touch anyway for those ones....
To be honest you are as well for all the hassle cutting open and soldering getting someone do this for you.
Balls it up (cutting open the case / soldering) and you'll be landed with a big bill for another one.
HLM will do an exchange .
I did mine last week with them and it could not have been simpler.
Call Hamish.
Volvo 855 2.5 10v CD
Its got everything except a turbo - boo hoo...
here's a link on how to remove/re-solder your abs
http://www.freewebs.com/dacvolvo/absrepair.htm.
850s had two different abs systems fitted.....
She may not be perfect but i love her anyway....
4mm socket does the job.
855 rica 304bhp, Adjusted Wastegate, Bleed Valve, ITG Panel Filter, 171k fsh, Volvo Strutt Brace, Polybush Topmount , 4mm Samco Vacuum Hoses, 10 Core "Racing" Ht Leads, 302mm Volvo Discs under 16" Columba Alloys, Performance DS2500 Fronts Red Stuff Rears, Drillled Airbox, 5w/40 Oil Changed @ 5k intervals,
764 B230ET 108k FVSH No mods yet...Planning underway.....
Dum Spiro Spero
VOC 850/70 Register Keeper
VOC 20419
Dum Spiro Spero
VOC 20419
Dum Spiro Spero
VOC 20419
Hey Jod
I tried for 2 months to find a Tracs Pump and ecu in this country that was not extortionatelly priced i.e. £250 + for a unit that hadnt even been refurbed !
I found 2 Tracs Pumps and Ecu's in America 1 for myself to use and one to sell, i payed £60 for my one and £35 for the one i sold on, I advertised it on ebay for £150 and some guy snapped my hand off
There are loads of Non Tracs pumps and ecu's knocking about though
Just a Tracs Ecu From the states is going for good money now.......http://cgi.ebay.com/ebaymotors/VOLVO...mZ190252916295
Lee
Dum Spiro Spero
VOC 20419
Hey Jod i think the non Tracs ECM is Ate Part No 9401541 and has a white label on it, the Tracs ECM is Ate part No 9401542 and has a blue label on it.
HTH
Lee
Jod T5 (Wednesday 5th November 2008)
Dum Spiro Spero
VOC 20419
cameron (Wednesday 5th November 2008)
well i was gonna do mine today but its p1ssin it down so this is gonna have to wait lolol
