anything I can look at or is it a dealer job
is it where the switches are for the aircon if so it means there is a fault with the aircon system or it needs regassing
pangster (Sunday 19th October 2008)
Yep and the the switch to the left as well! I have two flashing lights!
Thats it then its the aircon that has a prob or need regassing
damn! It's not even blowing air! That's gonna be a problem in the morning.
So should I get someone to regas it or take it to volvo?
Cost me £35 last time to get them read
Might just go for the regas and see if that fixes it!
When I start the car, the fan blows for appox 2-3 secs, it then turns off and starts flashing the two orange lights.
So would this be low gas?
not to sure (only had it a week!) will check tomoz, how long should it be between cycles?
could also be an interior temp sensor...
White '98 S70 T5 ME7
K&N panel filter
Drilled airbox
Ported 18T
Milltek Exhaust
Dark Anthracite Comets
'R' Bumper
2003 C70 Headlights
Autogauge smoked boost gauge
"Yeh, the T5 and T5R are handy bits of kit for transporting wardrobes across the country at monumental speeds."
Where is it?
Hi Beast, I've had the same thing happen only last week on my S70R. Quick fix was to take radio out and push the ac unit out from the back. Disconnect the wiring off the back and leave it off for about 10-20 secs. Put the wiring plugs back in and turn the ignition on. It may need a couple of goes but it does work. I put my dianostic reader into my OBD port and it showed no faults, ac was cold. so tried the above and it works fine again. It is also worth brushing the sensor as pangster said also.
Good Luck.
I do recall reading ,you can program the blower buy holding in the buttons for some seconds.
You can set it to demist your window screen (air con) for a short period,then stop ,or something.
Once they are set ,or programs loaded,they flash a pattern at you.
Its in the manual I think.I will check it.
Good luck
Cheers
I had this on my old 97 S70 T5, it turned out to be the blower motor. DEAD easy to replaced via the glovebox. The dealer did mine, but it was £300, which i refused to pay because I didnt give then authorisation
Theres some on Fleebay for about £20.00
As said before, also check the pollen filter
Also, my lights flash too, but my fan still works fine. My aircon isnt that cold, so Im guessing I just need a regas
Thankyou, Goodnight....much love
