Results 1 to 10 of 10
    d14vd_h's Avatar
    Mar 2005
    St Andrews
    0
    Exclamation Emergency!! Please Help Diy Hell
    help! ive broke my car FUEL PUMP RELAY FUSES??
    after the replies from my last post about the problem of my car sometimes losing power i decided to try some diy with haynes,
    it was suggested it may be my fuel pump relay
    i took out the ashtray to get access to my fuses and relays, saw that there was a fuse for the fuel pump took this out and wiped it etc made sure it was back in firm
    i then pushed my hand up to the back where the relays are and pressed them all down in case one was loose
    then i started the car up...
    but now instantly the idle is searching and goes very low and the car is very hesitant on acceleration!!!!!!
    what have i done,
    i have recently had the Idle air control valve cleaned and the oil pump replaced etc it was perfect unil i did this, this evening!
    have i dislodged something broke it or what!?!?!
    please please help
    vt5's Avatar
    Apr 2005
    Oldham
    0
    If youve not touched anything else at all, you may have damaged one of the relays when pressing them. Ive bought brand new ones and theyve not worked right.
    You may have to start a process of elimination......
    Go to a breakers yard and get a bunch of relays and fuses (the ones you touched) and replace them one by one......I did this and solved my problem, though that said it was nothing like your problem, but its a very cheap way to find out if you broke something.
    If not then have a word with the guys at Volvotuning who may have a better answer for you.
    siamblue's Avatar
    Nov 2004
    Ilford,Essex.
    747
    Maybe the Fuel pump relay know it has been removed has given up,If thats the only one you have removed then start with that one,Phone SALVO and ask how much they are,Won't be much or look on Ebay.
    Martinr's Avatar
    Feb 2005
    Stourbridge - West Midlands
    0
    I have a sheet that details how to test relays that was sent to me from a guy on the VOC forum.
    PM me with an e.mail address if you want a copy. It should help you trace the guilty party!
    Martin
    "Experience is something you don't get until just after you need it"
    855
    280 RICA
    ITG Panel filter
    Volvo strut brace
  5. #5
    d14vd_h's Avatar
    Mar 2005
    St Andrews
    0
    Thumbs up
    DONE IT!!!!
    i took it to the mecahnics first thing this morning asked them to check the relays in particular the fuel pump relay - they phoned me back and said there was a current going to it so it was fine,
    not convinved i went to volvo and bought both available fuel pump relays for the 940 ones green the other white
    this evening i followed the instructions replaced the relay - mine was white = cheaper of the 2 and its perfect - better than before on start up etc!!!!!
    volvo will take back the unused green relay which is just as well because its 50 quid.
    thanks for all the advice at least something good came out of my tampering as i reckon your right i found my intermitent fault by making it permanent!!!!
  6. #6
    siamblue's Avatar
    Nov 2004
    Ilford,Essex.
    747
    Nice one,Lots of smiles now then
  7. #7
    Shiny Superstar
    Back in the game!
    Wobbly Dave's Avatar
    Aug 2004
    Stunning Shropshire
    2,495
    He's back int'zone!
    Volvo ABS ECU Repair
  8. #8
    d14vd_h's Avatar
    Mar 2005
    St Andrews
    0
    Exclamation Wtf
    ARGGGGHHHHHHHHHH
    took the car out this morning, first startup revs dropped to low, switched ignition off started again sat perfectle at 700 revs
    started driving felt a little more sluggish than usual,
    then when i stopped my oil pressure warning light is on!!!!!!!
    after having a new switch and pump and changing to thicker oil it was solved how can it be back after replacing the fuel pump relay!?!?
    nightmare!
    ive put in some fortifier and a fuel system flush until i get down to the mechanics on fri.
    any idea!??!!?
    D14VD H
  9. #9
    d14vd_h's Avatar
    Mar 2005
    St Andrews
    0
    Question
    Found this on brickboard:
    "I've owned this car for 6 months with absolutely no problems except a noisy ps pump. Suddenly the oil light went on and i then heard the valves complaining of no oil pressure. After flushing the engine, replacing the filter, oil pump and associated tubes, pickups and valves, it still has the problem. From a cold start the engine will idle for hours, including running the rpms up, and the oil light stays off and there is oil pressure. Then a short trip down the road produces the light and valve noise. After a short cool down everything is ok. Sometimes the light goes on right from cold start up.
    Answer: The o-ring on the oil pump suction tube in the oil pan has been pulled inward allowing air to enter. While the pan is off the two o-rings at the pan-to-block joint need to be replaced also."
    think this may be my oil pump issue!?
    seems same symptoms and seems to have tried all the things i have.
  10. #10
    Justin's Avatar
    Aug 2004
    Midlands UK
    374
    Worth a try mate
    <a href="<a href=http://s65.photobucket.com/albums/h225/RobertBingley/Misc/?action=view&current=Animation1.gif target=_blank>http://s65.photobucket.com/albums/h2...Animation1.gif</a>" target="_blank"><img src="<a href=http://i65.photobucket.com/albums/h225/RobertBingley/Misc/Animation1.gif target=_blank>http://i65.photobucket.com/albums/h2...Animation1.gif</a>" border="0" alt="Photobucket"></a>
