hi folks,
The plan is to take the battle-bus to the 'Ring in October, so I've picked up some braided lines and new discs, pads etc, and wanted to fit them this weekend.
However, before I rip everything off, I just wondered if im going to be able to bleed them myself- or is it a bit of a pig because of the ABS and stuff? If so, will I need a special pressure machine to do it?
also, whilst Im doing the brakes, should I be thinking of upgrading the fluid to dot 7 or something, or will that be too ascorbic, and require changing every thirty seconds? If someone could let me know what you guys use, and how much of it to buy, that'd be aces.
many thanks in advance,
Nerv.
