Heres a question for you.
When the light comes ON on the dash, is it a "latched" light that needs to be reset before it will go out, or will it go out when the fault/condition nolonger exists (as in the fuel light on when tank low, then goes out when you put more fuel in!)
Reason for this is that I disconnected the MAF plug with the engine running, which brought on the light, but when I reconnected the plug, the light remained ON
