Before my T5, I had a 94 2litre 20v.
When starting the car, the brakes pedal would vibrate a couple of time and the ABS light would remain lit for a few seconds. This is described in the manual as an 'initial test'.
This does not happen on my 96 T5 - is it supposed to???
(I notice that the ECU and pump are different on the 2 models)
The car appears to brake ok - would probably benifit from a check over / bleeding - but passed MOT 5K ago.
if it helps, my ecu looks like the one dave has posted a picture of here....
http://www.volvot5.co.uk/forums/showthread.php?t=224
