im wanting to remove the aircon from my ovlov v70 t5 does anyone know if they made the T5 with out aircon as i need a shorter Timing Belt
Hiya,
phase 2's aren't my area of expertise but I'm pretty sure they'll have done a T5 without air-con. Maybe have a look at the selection of belts available on PartsForVolvos:
www.partsforvolvos.com
or ask Rufe who works in a Volvo parts department?
Cheers, Pete
'97MY black 855R manual M56H
Porsche/S60R BBK, 17"x8J Pegasus, RIP, Samco coolant & vac, Koni SSK/Nivo, Simota, 15G angle flange, IPD turbo back & HT, MSD coil, chipped, dimming mirror, Goodridge hoses, DOT5.1, V70 rear lights & handles, poly top bush & A arms & tie bar, strut brace, clear repeaters, 6k HID, catch tank, 2x rear brace
I don't think the timing belt drives the pump does it?, I thought that was the auxiliary belt.
Previous cars:
shemtek_racing (Wednesday 3rd September 2008)
Good spot TC! 'tis true, you *don't* want a shorter timing belt :-)
Cheers, Pete
cheers TC maybe i should have looked first lol a shorter AUX belt should be a peice of cake as long as the configuration of the pulley's allows you to miss out the air con pump with out the addition of a dummy pulley will have a good look this weekend ill post my findings if anyones interested?
Dont think there's a shoter aux belt, I think you have to buy a pully for it that just goes in place of the compressor.
IIRC loadsamiles has removed his this way......
White '98 S70 T5 ME7
K&N panel filter
Drilled airbox
Ported 18T
Milltek Exhaust
Dark Anthracite Comets
'R' Bumper
2003 C70 Headlights
Autogauge smoked boost gauge
"Yeh, the T5 and T5R are handy bits of kit for transporting wardrobes across the country at monumental speeds."
yeah i think you can match up a belt from the numbers on them i think the belt is groved both sides is that right?
Removed the air con from my 850, well RT removed some and I removed the compressor. Shorter belt from Rufe no problem. Exept on our sweltering summer when the air con comes in handy...not.
Paul
had a good look at doing this the only problem i can see is that the belt will have much less contact with the alternator pulley how much contact does there need to be for it not to slip?
