As title says, how the hell to you get the backs off of these wing mirrors???
I have a C70, and want to replace both mirrors, but I want to swap the backs, as the replacement units are the wrong colours!
Cheers
Paul
Cheers
Paul
Thankyou, Goodnight....much love
Clip a telegraph pole?
Alastair
If memory serves me. Take the mirror out/off and you'll see the inside back of the wing mirror and housing. You should see some plastic clips that are attached to the covers that holds it to the door mirror. Pinch these together and push and it should come off. Dont forget the ones closest to the door frame too.
Liddo (Tuesday 26th August 2008)
Cheers for that, BUT! Have you ever tried to remove the mirror itself??? I read the distructions on here, i.e Tilt the mirror ALL the way up, and then yank on it. Well, I did this, and would it ££££ come off! How hard have ya gotta tug on it for gods sake? Felt like I was going to smash the mirror in my hands.
Anyway, the only reason I need to change them, is the drivers side wont go left to right, but you can hear the motor going, and the passenger mirror wobbles on the motorway, like the glass is loose A right PITA
They do just pull off but they are DAMN TIGHT!. The mirror backs on 850's are held on by small torx screws behind the glass, not sure if it's the same for C70's.
Previous cars:
Liddo (Wednesday 27th August 2008)
yer give it a good pull. If you can hear the motor running and the mirror doesn't move, could be the little plastic bits that connect the motor to the mirror are broke. That's what happened when someone hit my wing mirror.
I just went on ebay and got a replacement one as it was cheaper and easier then getting a new heated mirror and fixing the broken plastic arms on the motor
If you fold your mirrors in so the mirror glass is facing the door window, isn't there two small tabs located in the now exposed end of the mirror housing, I'm sure you can press these in and then 'work' the housing off......not sure though...lol
yep fold right in tight,,,press on two clips an they come off,,,,,
Liddo (Sunday 21st September 2008)
