OK, this is bugging me... any suggestions please guys?
1999 S40 T4, hasn't been boosting right for a while. Trying to get it back to 1.0bar stock boost.
Originally was boosting to just 0.4bar, suspected the boost control solenoid so replaced with a Blitz dual-spec R boost controller (good for 2+bar) that I had lying around. Now we get 0.7bar but no more, even with the Blitz wound right up to 100% (a bit scary trying THAT!)
The car spools up nicely to 0.7bar but then will just hold 0.7 and dump the excess boost to atmosphere. Quite an abrupt effect, I could believe that the Blitz was cutting in early but can't see any evidence for this.
Checked for the usual air leaks etc, nothing found. Wastegate actuator feels reasonably tight, not sloppy.
Currently has an atmospheric DV AND the standard recirc, which might be causing the issue? I'm blanking off the recirc valve later this week to see if that might help...
What else can we think of?
