help i have a c70 t5 gt 99 manual and when i drive FAIRLY not heavily and when on a long run i get and eggy smell coming from the car? could it be the cat? all comments aprreciated?
Yep.
________________________
Apple Mac help required?
Need assistance with your iPad, iPod or iPhone?
Being harassed by the spinning beach ball of death?
Get in touch with The Mac Doctor now.
(Covering Norwich and Norfolk)
c70Portree (Tuesday 5th August 2008)
thank you!!!! what does it mean tho? will i need a new one?
No, it means it's working fine. All cats make this smell. You may want to check the boot seal though if the smell is coming in as you drive.
thanks france for that!!!!!!
were you chasing a car with a cat when you were pushing hard? You will get the smell of his cat coming in your vents
yes the sulphur smell is from the cat, you may find that changing the petrol supplier you use may help if the smell is very noticeable (i have heard this in the past, but cant say i've ever had to do this in the past)
FRF FEEDBACK (click here)
(Mon to Fri 9am to 5pm)
Interesting comments - I had a fairly smelly exhaust when my Lambda sensor was on its way out and I was running rich. Maybe the excess fuel caused additional problems with the catalytic convertor and led to more smell? It doesn't smell bad after a run now.
Cheers, Pete
'97MY black 855R manual M56H
Porsche/S60R BBK, 17"x8J Pegasus, RIP, Samco coolant & vac, Koni SSK/Nivo, Simota, 15G angle flange, IPD turbo back & HT, MSD coil, chipped, dimming mirror, Goodridge hoses, DOT5.1, V70 rear lights & handles, poly top bush & A arms & tie bar, strut brace, clear repeaters, 6k HID, catch tank, 2x rear brace
neither does mine strangely enough....
855 rica 304bhp, Adjusted Wastegate, Bleed Valve, ITG Panel Filter, 171k fsh, Volvo Strutt Brace, Polybush Topmount , 4mm Samco Vacuum Hoses, 10 Core "Racing" Ht Leads, 302mm Volvo Discs under 16" Columba Alloys, Performance DS2500 Fronts Red Stuff Rears, Drillled Airbox, 5w/40 Oil Changed @ 5k intervals,
764 B230ET 108k FVSH No mods yet...Planning underway.....
Dum Spiro Spero
VOC 850/70 Register Keeper
VOC 20419
