Page 1 of 2 12 LastLast
Results 1 to 20 of 34
Thread: imiv fitting
    Member
    Mar 2005
    0
    imiv fitting
    right, i have ordered a imiv kit for my p2 V70.
    i got the front install kit, so hopefully i can mount the ipod in the glovebox/arm rest.
    can anyone gimme any hints/tips on what i am going to have to go through to get this fitted and looking good.
    cheers
    2002 V70 Bi-Fuel
    Looking for ways to make it better and faster
    (tried throwing it off a cliff, its still slower than a granny in a metro )
    Member
    Jul 2008
    1
    I've just fitted one a few days ago. Piece of piss!
    Right here goes.
    1. Pull out pen holder (be care full not to break it!)
    2. Unscrew air con unit torx screws (the two closest together)
    3. Pull away air con unit from radio (connected by spring clips)
    Be careful not to yank the air con unit out so much as to disconnect the wires as I read on tinternet that you'll need a dealer re-set! Lay the air con unit at a 45degree angle (just resting on gear knob).
    4. Unscrew the two radio bracket retaining torx screws (on mine anyway HU-803)
    5. The the complete radio and cup holder should just lift out now. I read lots of articles that once unplugged Volvo dealer will need to re-set or download software to the car. On my 2003 S60 it is plug and play, no re-set needed.
    6. Unconnect plugs from back of head unit.
    7. I found the most convinent place to mount iMiv was in the glove box. As you are looking into in with it open mine sits on the top so when the glove box is open its not that obvious unless you are looking for it.
    My ipod is in the arm rest. Route the ipod cable down the back of the aircon unit and feed along transmission tunnle (remove plastic trim in passenger footwell which runs either side of transmission tunnel), then open arm rest and pop out base. You will now have a view of what I think is to retaining fly bolts for handbrake. You can now pass up ipod cable into arm rest.
    8. Route melbus, ipod and power cables to imiv.
    9. Connect melbus cable to imiv, then ipod cable, then power. I purchased the volvo power cable which you need a seperate lead (part 9204981)from volvo for. This connects to the green power socket in the back of the head unit and the other connections are the corresponding male plug for the car and another white plug which you need to plug the Imiv cable to. If you purchased the generic cable which you need to splice into the cars power, I cant help you!
    10. Connect ends to back of head unit and test its all working. You will hear the head unit whir up into life but it won't turn on till you turn the ignition on.
    On your head unit you should see CDC changer. This is the pre loaded firmware on the imov. To get track titles you have to down load the MD changer firmware.
    To down load new firmware follow the intructions on the Imiv web site and you will have track titles!
    This lot should only take about an hour or two. Once all connected up you won't look back!
    Once its all working re-fit head air con unit first (be carefull not to disconnect it!) then head unit.
    Junior Member
    saufboy's Avatar
    Jul 2008
    West sussex
    6
    Where did you boys get this set up from and how much was it delivered,
    Cheers
    Julian
    2003 V70 T5 Ex Hampshire Constabulary
    Member
    Jul 2008
    1
    I ordered mine direct from iMIV see here: http://www.imiv.ca/cms/
    I chose the cheapest UPS delivery and my iMOV arrived in 3-days. In fairness they sent me the wrong melbus cable, but after a quick email they sent me out the correct one free of charge. That arrived in three days as well!
    The kit which includes the iMIV, melbus cable, ipod cable and volvo power cable 9to be used with Volvo wiring harness, came to £120.
    I got clobbered for import tax which was £20. According to the UPS delivery driver, she told me everything coming in from Canada and the US is getting stung for import tax. The volvo wiring harness (power) is about £17 ish from a Volvo dealer which makes everything plug and play.
    All this lot maks the CD player redundant! Just as well cause the one in my Hu-803 is knackered.
  5. The Following User Says Thank You to D5 Stunt Man For This Useful Post:
    saufboy (Saturday 9th August 2008)
  6. #5
    Junior Member
    Mikesmith999's Avatar
    Jul 2008
    London
    0
    I had mine fitted in my S60 by a local car audio shop for £50 (bandit).
    However, the imivis in the cavity at the end of the dash, accessed through a hatch visible when you open the door.
    My CD player still works as the Imiv added a CD multi changer channel to the HU.
    I then downloaded a software upgrade for the Imiv that gives a Minidisk changer channel.
    If you run your Ipod on "MD changer" your HU will display track, album and playlist names.
    The power cable came with the Imiv, It is a splitter cable that you plug the existing power source into, then it has two plugs running of it. one for HU and one for Imiv.
    Artificial intelligence can't replace natural stupidity
  7. The Following User Says Thank You to Mikesmith999 For This Useful Post:
    saufboy (Sunday 10th August 2008)
  8. #6
    Member
    Mar 2005
    0
    mines a birthday present, so i dunno ho much it was.
    ours arrived in 3 days via fedex, but with no import duty
    does anyone else use the second imput in the imiv, i am thinking about connecting a portable DAB radio
    have the feling this is going to start me on that slippery slope o wanting subs and amps again
    2002 V70 Bi-Fuel
  9. The Following User Says Thank You to MrP For This Useful Post:
  10. #7
    Junior Member
    saufboy's Avatar
    Jul 2008
    West sussex
    6
    Thanks chaps, so is there a simular way of doing it without having to buy from the other side of the water, a product in the uk so to speak??
  11. #8
    Member
    Jul 2008
    1
    Quote Originally Posted by saufboy View Post
    Not that I'm aware of.
    To be fair I'd rather buy it direct from the manufacturer as if anything goes wrong or I need any technical questions answering, I can ask the people that make it!
  12. The Following User Says Thank You to D5 Stunt Man For This Useful Post:
  13. #9
    Member
    Mar 2005
    0
    got it fitted in the end!!
    took me 3 hours to get everything back in, cables routed and it looking neat and tidy.
    the adapter is in the top of the glove box, but i need to stick it down yet, cables are run along the transmission tunnel and into the arm rest, and i cut a slot to thread the cables through.
    the radio/aircon control unit are pigs to get out, i took ages untill i teased it out using more force than i was comfy with.
    cables were really use to use, but it took me ages to work out how to get the stereo back in (top of the head unit how to slot under a metal bracket before you push the bottom back into place.
    as mine an auto, i had to leave the keys in and ignition on so i could move the gear leaver back in order to have enough space to work, this then rewarded me with a flat battery once i got everything assembled!
    anyway, its all in and working, i just have a problem with the aux input being really quiet no matter what i plug in, so i think i'll have a go with the firmware and see if it works better on another source
    2002 V70 Bi-Fuel
  14. #10
    Member
    Jul 2008
    1
    Quote Originally Posted by MrP View Post
    Glad you got it installed.
    I wouldn't be without mine now!
    Someone on this forum posted about tracks recorded in aything but Apple lossless sounds flat on the Dolby headunit.
    I dunno about you, but I can't tell the difference between 128kbs and Apple lossless!
  15. #11
    Member
    Mar 2005
    0
    yeah, i set the wifes pc only to use lossless, but i havent tried anything that shes downloaded yet.
    is the firmware update easy to do?
    2002 V70 Bi-Fuel
  16. #12
    Member
    Jul 2008
    1
    To be fair I crapped myself when I did the firmware but actually its not that difficult.
    Download the relevant firmware (mini disc changer for text) and and put the file in your i tunes music folder which is more than likely in My Music.
    The firmware file is actually a .WAV file.
    Once you've placed the firmware file in the correct folder you should now see it in your i tunes musuc library. Copy the file to your ipod.
    At this point it would be worthwhile downloading the imiv owners manual from the imov website. The manual will tell you how to put the imiv into updating mode (I cannot remember!)
    Once you've installed the firmware you will then have scolling text for artist & album name and track name.
    One thing that is worth doing is numbering your playlists 01, 02 etc as the imiv wil display the name of the playlist you are playing and without it, it won't.
  17. #13
    Mar 2005
    kent
    10
    Just reading through this lot & i am still confused ! I have a 2003 V70 R with an HU803 4 disc in dash player, the car has no sat nav or boot changer. I am quite capable of working on my own cars, just fitted a IPod compatable head unit to my M3 which is great but we are still using a griffin i trip in the Volvo. The IMIV kits seem to be the only ones that will do the job properly, can you use the steering wheel controls, anybody got an idea what kit & leads i would need ,it just seems confusing to me as depending on what is fitted to your car sat nav etc what leads you need. Is the sound noticably better than through the FM transmitter ?
    Thanks Simon.
    BMW F80 M3 & modded 854 T-5R
  18. #14
    Member
    Mar 2005
    0
    the sound is superb from what i have played so far, obviously being MP3's your mileage may very depending on the quality of the recording
    the imiv website has a wizard on it, so you should just choose the options and it will tell you what cables you need.
    i got a front mount kit, with a 200cm cable, apart from the cable you need from volvo (which rufe can supply) everything is there. i mounted my cables in the armrest cubby hole which works well and hides the cable (i had to cut a small hole in the bottom of the cubby box)
    the kit is literally a matter of connecting 4 cables up, its just the time taken to disassemble the dash and re-assemble which is a pain
    2002 V70 Bi-Fuel
  19. #15
    Mar 2005
    kent
    10
    Looking on the IMIV site it asks whether the car is Melbus prepped & RTI (dvd) what the hell does that mean ! How do i know if my car is melbus prepped ? What is RTI ?
    Cheers Simon.
  20. #16
    Mar 2005
    kent
    10
    ok RTI means sat nav & mine is not melbus prepped,sorry !!
  21. #17
    Member
    Jul 2008
    1
    Quote Originally Posted by simonc View Post
    Dude this is what you need:
    http://tinyurl.com/6df7w7
    http://tinyurl.com/5z8rln (200cm cable for front install)
    http://tinyurl.com/65uswy
    Use this cable in addition to Volvo harness - part number 9204981. Order from Rufe.
    http://tinyurl.com/5c4dme
    80cm Melbus to Hu cable for front install
    Or you could just use the wizard here: http://tinyurl.com/5ruw53
    I've just noticed that you are in Kent (me to) where abouts?
    By the way M3 Evo - Nice. E36 by any chance?
  22. #18
    Mar 2005
    kent
    10
    Hi, yes its a late S plate E36 in estoril it replaced a 3dr Sierra Cosworth that i had before,the M3 is more useable. I'm near Herne Bay.
    I'll have a check through those links,thanks.
    Simon.
  23. #19
    Mar 2005
    kent
    10
    OK thanks i have just ordered all the bits from overseas. Just need to order the power cable 9204981.
    Thanks Simon.
  24. #20
    Member
    Jul 2008
    1
    Thanks Simon.
    Give Rufe (Simon @ FRF Motors) a bell 01792 790066, he'll give you a discount. The Volvo wiring harness works out about £17 delivered IIRC. The wiring harness just taps into where the power goes into the back of your HU and allows you to plug the in the power for the imiv rather than splicing into the cars power.
    You are only down the road from me, I'm in lovely Medway as in the River Mudway.
