Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    stainesy's Avatar
    Jul 2008
    dunstable
    10
    auto gearbox oilm change
    ok peeps am changing auto gearbox oil saturday.
    what am i going to need?
    15 litres of dexron 3
    bit of clear rubber hose.
    a few buckets to catch oil.
    anything els i will need?
    Shiny Superstar
    Back in the game!
    Wobbly Dave's Avatar
    Aug 2004
    Stunning Shropshire
    2,501
    you need a spanner to open the box sump. Once all of the ATF has run out, and you've put the plug back in you need to flush change - putting in 1 litre or so (via the dipstick hole) and then running it out - I used the connection tube to the cooler to do this. Once the fluid runs clear - then you should fill using the yellow dipstick to the correct level.
    Volvo ABS ECU Repair
    freaky fingers's Avatar
    Jul 2008
    24
    Small bag of kitty litter to clear up any spilt oil.
    Wobbs would he need a new copper ring gasket for the plug?
    Nov 2006
    Cambridge
    21
    Hiya,
    don't think the sealing washer is copper, thought it was aluminium. It's the same as the engine oil sump plug washer I believe.
    Easiest to source from a dealer I've found.
    Cheers, Pete
    '97MY black 855R manual M56H
    Porsche/S60R BBK, 17"x8J Pegasus, RIP, Samco coolant & vac, Koni SSK/Nivo, Simota, 15G angle flange, IPD turbo back & HT, MSD coil, chipped, dimming mirror, Goodridge hoses, DOT5.1, V70 rear lights & handles, poly top bush & A arms & tie bar, strut brace, clear repeaters, 6k HID, catch tank, 2x rear brace
  5. #5
    Filterlab's Avatar
    Jul 2008
    Long Stratton, Norfolk
    257
    DON'T USE DEXRON 3! It's not suitable for your gearbox and if it has been used then it's likely to be causing the slippage. Contrary to popular belief Dex3 and Dex2 are not necessarily interchangeable. You should used either of the following two ATFs:
    Castrol TQ-D (Dexron rated IID & IIE)
    -or-
    Amsoil synthetic transmission fluid.
    ________________________
    Apple Mac help required?
    Need assistance with your iPad, iPod or iPhone?
    Being harassed by the spinning beach ball of death?
    Get in touch with The Mac Doctor now.
    (Covering Norwich and Norfolk)
  6. #6
    stainesy's Avatar
    Jul 2008
    dunstable
    10
    what? for god sake peeps what oil am i sposed to be using hear. can only use dex 3 now dont use dex 3. what do i use?
    also witch pipe is the gearbox oil return pipe?
  7. #7
    Moderator
    y2blade's Avatar
    Nov 2005
    The Shire
    1,197
    Quote Originally Posted by stainesy View Post
    my w/shop manual says DEXRON 11E type automatic transmission fluid
    hope that helps mate
  8. #8
    stainesy's Avatar
    Jul 2008
    dunstable
    10
    there are 4 pipes coming out of my radiator that look like they are oil pipes.
    2 on the left top and bottom and 2 on the right top and bottom. as you stand looking at the car from the front. witch one of these pipes is the one that goes to the gearbox that i have to take off to flush oil out of?
    and how is it atached to the gearbox?
  9. #9
    Gizza job!
    Yosser's Avatar
    Jul 2008
    The 1980's
    161
    This might help you;
    http://volvospeed.com/Repair/Transflush.php
    I flushed mine by removing the pipe which is at the right of radiator at the top - as you look at the car from the front (battery side).
    This pipe is the feed to the cooler. Ideally you should use the pipe from the cooler, but it's far harder to get to.
  10. #10
    Gizza job!
    Yosser's Avatar
    Jul 2008
    The 1980's
    161
  11. #11
    stainesy's Avatar
    Jul 2008
    dunstable
    10
    can i flush it by taking off the feed to the cooler and ataching the clear pipe to the cooler?
    that would work wouldnt it?
  12. #12
    Filterlab's Avatar
    Jul 2008
    257
    Definitely use a fluid that's Dexron IIE compatible only.
  13. #13
    Gizza job!
    Yosser's Avatar
    Jul 2008
    The 1980's
    161
    If you mean the pipe at the top on the right, then no.
    Attach the clear pipe to the flexible pipe, thats the direction of flow.
  14. #14
    stainesy's Avatar
    Jul 2008
    dunstable
    10
    Quote Originally Posted by Yosser View Post
    lol yeah thats what i ment. realised what i said after i put it.
    but tha wont flush the cooler will it?
  15. #15
    Nov 2006
    Cambridge
    21
    Hiya,
    the cooler holds barely any fluid as I found out when I added an extra autobox oil cooler. I really wouldn't worry about it.
    If you really want to drain it, disconnect the bottom hose and catch what comes out in a measuring jug so you can see how much to add back in afterwards.
    HTH, Pete
  16. #16
    stainesy's Avatar
    Jul 2008
    dunstable
    10
    what size spanner do i need to remove the drain plug from the bottom of the auto gearbox?
  17. #17
    siamblue's Avatar
    Nov 2004
    Ilford,Essex.
    747
    On my V70R it was a 22MM and it was FT had too use 2 spanners linked together to undo it,
    Gary
  18. #18
    stainesy's Avatar
    Jul 2008
    dunstable
    10
    FT? does that mean foookin tight?
    na think mine is 24
  19. #19
    siamblue's Avatar
    Nov 2004
    Ilford,Essex.
    747
    Could,ve been 24, but it was tight lol,
    Gary
  20. #20
    Moderator
    y2blade's Avatar
    Nov 2005
    The Shire
    1,197
    is it any better now stainesy???
