I have been skinned on both arms both sets of knuckles and have been bent up into more obscure positions than harry houdini today attempting to remove my servo, i now need help!
I released the pedal box side and all the couplings, master cylinder, engine mounts and even removed the heat sheilds fron the manifold, as i withdrew the servo it hit the head and i hit mine, 5hs being ultra careful and this happens, i have looked at the setup and there appears to be no way to gain the extra clearance to remove it without either, dropping the subframe and tilting the engine or removing the head, either of these is too big a job for me at home so can anyone suggest a better way if there is one, i cant see a way of removing the piston link arm that goes to the pedal either.
