Results 1 to 17 of 17
    Glad im Back -D
    cameron's Avatar
    Jul 2008
    Oldham, Lancashire
    983
    Unhappy Steering wheel shake !!!!!!!!!!!!!
    I have changed the wheels on my T5S to 17" Wolfrace,
    I had the wheels balanced, as there was a shake in the steering wheel accelerating between 50 - 70mph, this didnt help, so i got the tracking done, this didnt help, the tyres are all good, but i have noticed some uneven wear on them, and one wheel is pretty badly scuffed, i got this one balanced and they didnt say anything about the wheel being " buckled " so i am stuck now for things to try.
    Any suggestions?????????????????????
    Singing in the rain!
    CONDYBOY's Avatar
    Jul 2008
    North East England
    36
    Take it back defo sounds like a buckled wheel. ask the to put it onto the balancer and this time you watch for the wheel "wobbling" If it does ask for your money back as you can't balance a wobbly wheel.
    "I am never wrong! Just in a position to learn something new!"
    Mods so far, HLM ReMap, Goodridge brake lines, Eibach springs lowering 35mm, K&N57i filter with cold air, Strut brace, Shark fin aerial, Boost guage
    YES IT'S A DIESEL
    Wish list, BOV, 18" rims, Struts, Stainless exhaust, Injector Upgrade, MORE POWER!
    Nov 2006
    Cambridge
    21
    Hiya,
    I've had steering wheel wobble from a worn wishbone ball joint before.
    HTH, Pete
    '97MY black 855R manual M56H
    Porsche/S60R BBK, 17"x8J Pegasus, RIP, Samco coolant & vac, Koni SSK/Nivo, Simota, 15G angle flange, IPD turbo back & HT, MSD coil, chipped, dimming mirror, Goodridge hoses, DOT5.1, V70 rear lights & handles, poly top bush & A arms & tie bar, strut brace, clear repeaters, 6k HID, catch tank, 2x rear brace
    Alan M's Avatar
    Jul 2008
    Midlands
    46
    Ihad a wobble from worn control arm bushes too. Check them over first.
  5. #5
    Glad im Back -D
    cameron's Avatar
    Jul 2008
    Oldham, Lancashire
    983
    Quote Originally Posted by dooby View Post
    Hiya,
    HTH, Pete
    It only does it when accelerating, im stumped, it had new wishbones last year, the drop links look okay, and the ball joints look okay also.
  6. #6
    Glad im Back -D
    cameron's Avatar
    Jul 2008
    Oldham, Lancashire
    983
    Quote Originally Posted by Alan M View Post
    Worn control arm bushes?????? give me a name i'll understand please, im common i dont know posh names sorry.
  7. #7
    Trader
    No Longer a trader.
    Tomcat's Avatar
    Aug 2004
    Sunning it up in Chorley
    2,980
    Wishbone bushes....that's what he means....
    Previous cars:
  8. #8
    Glad im Back -D
    cameron's Avatar
    Jul 2008
    Oldham, Lancashire
    983
    Quote Originally Posted by Tomcat View Post
    Cheers T.C., are these easy to replace? how much? also would these not be replaced when the wishbones were done last year?
  9. #9
    Trader
    No Longer a trader.
    Tomcat's Avatar
    Aug 2004
    2,980
    I've never replaced a wishbone but I would have thought they'd come with new bushes in them.
    Previous cars:
  10. #10
    Glad im Back -D
    cameron's Avatar
    Jul 2008
    Oldham, Lancashire
    983
    My thoughts exactly ! So should i go down the buckled wheel route or what?
    It was on the front and someone said put it on the back and you will see a difference, i did this but it was exactly the same, i am completely stumped.
    Time for a trip to the stealers me thinks
  11. #11
    Straker's Avatar
    Jun 2005
    Brentwood, Essex
    1
    I wouldn't worry about it they "all do that sir". My 850 is the same and mechanically there is nothing wrong with it. It's a combination of low body stiffness and I suspect to improve crash they don't fix the coloums to the body as well as other OEM's.
    Chalk it up to the car's character and don't worry about it.
    1995 850 T5, Auto
    MODS
    17" tethys
    BSR Induction kit
    Reverse IC
    Strutt brace
    Poly topmount
    Poly LCA bushes
    302mm Brake conversion
    Braided hoses
  12. #12
    Jod T5's Avatar
    Oct 2005
    Near Chelmsford Essex
    5
    Tbh vibration around the 60mph make is usually sure fire balance issues. I would get this double checked and ensure the tyre is correctly seated on the rim....
    cheers
    jod
    855 rica 304bhp, Adjusted Wastegate, Bleed Valve, ITG Panel Filter, 171k fsh, Volvo Strutt Brace, Polybush Topmount , 4mm Samco Vacuum Hoses, 10 Core "Racing" Ht Leads, 302mm Volvo Discs under 16" Columba Alloys, Performance DS2500 Fronts Red Stuff Rears, Drillled Airbox, 5w/40 Oil Changed @ 5k intervals,
    764 B230ET 108k FVSH No mods yet...Planning underway.....
    Dum Spiro Spero
    VOC 850/70 Register Keeper
    VOC 20419
  13. #13
    Glad im Back -D
    cameron's Avatar
    Jul 2008
    Oldham, Lancashire
    983
    Im thinking about putting the origonal wheels back on her, it was fine till i changed them over, just have to find some now, and try and sell my 17" ones.
  14. #14
    Jod T5's Avatar
    Oct 2005
    5
    Quote Originally Posted by cameron793 View Post
    that seems to cast iron the theory that either the wheels themselves are unbalanced or the tyre damaged or incorrectly fitted
    cheers
    jod
    Dum Spiro Spero
    VOC 20419
  15. #15
    Member
    ShadeTek's Avatar
    Jul 2008
    16
    Wink
    I remember watching a "Jock's garage" on Sky TV and a guy came in after fitting new alloys complaining of wheel wobble. It was his new alloys which had buckled after going over potholes and such like. Jack your car up and spin the wheels and see if they are warped. Also try swapping the front and the rears to see if that moves the problem.
    Long time no see Jod. See you over at "the other place We dareth not mention", very soon.
    Thx
    Tek
    Emo vilis emo bis
    2003 V70 SE, 5244 S2, 2.4 24v, 101,000 miles
    Mods: Yatour MP3 CD Emulator
  16. #16
    Glad im Back -D
    cameron's Avatar
    Jul 2008
    Oldham, Lancashire
    983
    Quote Originally Posted by ShadeTek View Post
    I remember watching a "Jock's garage" on Sky TV and a guy came in after fitting new alloys complaining of wheel wobble. It was his new alloys which had buckeld after going over potholes and such like. Jack your car up and spin the wheels and see if they are warped. Also try swapping the front and the rears to see if that moves the problem.
    ShadeTek i took the one i think is buckled off the front and put it on the rear and still the shake, im stuck!
  17. #17
    Member
    ShadeTek's Avatar
    Jul 2008
    16
    Maybe they're all warped?
    Thx
    Tek
    Emo vilis emo bis
