Hi guys and girls,
My '99 T4 has a problem - the indicators don't work (direction stalk or hazards). They DO however flash when I set the alarm!
"Hazard" Fuse is OK FWIW.
Any suggestions please?
Hi guys and girls,
Alastair
sounds like relay problem
Al if you tell me which one it is i am sure i have a spare here i can post out to you,
Gary
Are you sure you havent sat in BMW by mistake?
its probably the flasher relay, pretty common on the S and V 40's
Part number is 30870939, its a black relay with a white plastic bracket around its base, if thats any help to you
(i can supply these if you cant get one elsewhere)
FRF FEEDBACK (click here)
(Mon to Fri 9am to 5pm)
LOL I saw that coming!
Word on the street is that it's the flasher relay down by the accelerator pedal.
Fortunately I have a second T4 here so I will swap them and let you know - Gary I might well be knocking on your door!
Alastair
How did you get on? I take it that the alarm works on a seperate relay to the indicators?
"I am never wrong! Just in a position to learn something new!"
Mods so far, HLM ReMap, Goodridge brake lines, Eibach springs lowering 35mm, K&N57i filter with cold air, Strut brace, Shark fin aerial, Boost guageYES IT'S A DIESELWish list, BOV, 18" rims, Struts, Stainless exhaust, Injector Upgrade, MORE POWER!
I removed the old one but it was SUCH a pain to remove I didn't swap the other one from my second T4, instead I'm just going to get a new one, and test it. So no news as yet...
Alastair
my s70's indicators now dont work at random intervals, I've found if I wiggle the key in the ignition they work dont know of yours is similar problem...
White '98 S70 T5 ME7
K&N panel filter
Drilled airbox
Ported 18T
Milltek Exhaust
Dark Anthracite Comets
'R' Bumper
2003 C70 Headlights
Autogauge smoked boost gauge
"Yeh, the T5 and T5R are handy bits of kit for transporting wardrobes across the country at monumental speeds."
no on the P1 models its probably a faulty connection with the ignition barrel, which means a new complete steering lock to sort it. This was a fairly common fault to be honest. While your indicators don't work, you will probably find most of the other electrics are not working either, like headlights etc. its usually a case of just making a small turn to the key to get them to work.
doh!
I had a feeling you were gonna say that, any idea how painful it is to fix? and do I have to go to a local stealer or is it something I could get through yourself? Had noticed some other lights weren't working the first time it did it, dont think its something i should ignore cos one day it'll stop coming back on and you just know it'll be dark...
K&N panel filter
Drilled airbox
Ported 18T
Milltek Exhaust
'R' Bumper
2003 C70 Headlights
it depends on your skill level with a spanner, its a fairly tricky job but not impossible for the DIYer.
a new column lock (coded to existing key) is towards £180 these days, though i can bring the price down a bit. you swap over the antenna ring from the old one so you can use the existing keys and no need to get any programing done.
## UPDATE ##
I changed the flasher unit relay and still have the problem!
Alarm still flashes the lights, but hazards do not and indicator stalk does not either.
What else could be at fault??
Thanks for any advice. It's WINDING ME UP
Alastair
Is your air con workin and fan/DOES YOUR HIGH BEAM WORK ASWELL
I have no aircon and yes the high beam works...
Alastair
Perhaps the switching unit itself or a loose wire on the back breaking the switch circuit then.
Drop the steering column cover off and have a look at the back
i had a similar problem where indicators,aircon,fan,and dash lightin n stuff found out that wirin loom at front of car somewhere near radiator had rubbed thru apparentely a common prob on p1 v40
Thanks Enigma and Mark.
Enigma - both the hazards and indicator stalk are broken so I hope it's not the switch(es)
Mark - I'd heard about this problem but forgotten - will check the wiring loom right now.
Alastair
Damn - wiring loom looks fine
So it's not the switches, not the fuse, not the relay, not the indicator bulbs, and not the wiring to the bulbs from the loom.
I suppose maybe the wires from the hazard switch and indicator stalk might join up in the cabin to go out into the engine bay. Does anyone have access to a wiring diagram to confirm?
Alternatively maybe one of the switch connectors has become dislodged - and maybe they both have to be plugged in to work (ie there's some kind of pass-through going on...) I'll check that too.
Any other ideas guys?
Alastair
is the sealbelt warning light flashing and ticking?
