Results 1 to 10 of 10
    Junior Member
    Nov 2006
    0
    where vacumn source is for the stock boost gauge and what are is the voltage range
    All,
    Two qestions..
    1. Where is the vacumn source for the stock boost gauge?
    2. What is the voltage range the stock narrowband o2 sensor runs at...
    i.e what is the stoichmetric range at cruise and stickover and what is the ideal voltage at full throttle?
    Thx
    volvotuning's Avatar
    Oct 2004
    0
    Quote Originally Posted by Bigguy0482
    All,
    Two qestions..
    Thx
    1. Same as the pressure source. Inlet manifold.
    2. Normally switches between 0.2V and 0.8V. It's completely non linear though. Come to think of it, it's not linear on wideband either but it's a much simpler curve to interpolate from. You will struggle to get a stoich reading of lambda 1.0 with a narrowband sensor. That's why the ECU uses the average values of the voltage swings to work it out.
    Solution is simple - get a wideband!
    Adam.
    Junior Member
    Nov 2006
    0
    Quote Originally Posted by volvotuning
    2. Normally switches between 0.2V and 0.8V. It's not linear though. Come to think of it, it's not linear on wideband either! You will struggle to get a stoich reading of lambda 1.0 with a narrowband sensor. That's why the ECU uses the average values of the voltage swings to work it out.
    Adam.
    Thanks adam,
    My voltage seems to cycle between 0.8v to 1.0v (cruise/idle) do you think i have a dodgy lambda probe??
    at rich it seems to peg to 1.0 v
    Oct 2004
    0
    Thanks adam,
    Don't know. Is the fueling ok at idle and at cruise?
    Adam.
  5. #5
    Junior Member
    Nov 2006
    0
    it just seems to cycle at those values .8 to 1.0 volt.... i have a decat though... and one of your ecu upgrades...
  6. #6
    Junior Member
    Nov 2006
    0
    just seems to cycle between .8 to 1.0 volt at idle and the same at cruise.... it has a decat on with some of your decat software on it...
  7. #7
    Oct 2004
    0
    like I said, get a wideband and you will know exactly what it's doing.
    Adam.
  8. #8
    May 2005
    Suffolk
    22
    Im sure you can get widebands with a gauge for around £200 if you look hard enough, hope that helps.
  9. #9
    Junior Member
    Nov 2006
    0
    Adam.
    Im wondering where it could be fuel pressure, adam in your rica upgrades do you change the fuel pressure?
  10. #10
    Oct 2004
    0
    No. Fuel pressure is not changed on the 850 T5. I don't understand what you are trying to do? If you want to know how it's fueling, ie AFR, then get a wideband. If you want to know the fuel pressure, get a fuel pressure gauge.
    Adam.
