Results 1 to 6 of 6
    Member
    Sep 2006
    Milton Keynes
    0
    reset ECU with odd results.
    As a lot of you will have seen i have had issues with my cars running.
    Yesterday the codes were read - with it coming up "NO DTC SET"
    Today in other work the battery was removed, and when i picked it up i assume it had reset.
    And the car runs like a dream.
    Any thoughts on why this is? I would have assumed it would run worst when reset?
    Paullyp's Avatar
    Mar 2005
    Outside Sunny glasgow
    0
    It is likely that when you reset the ECU, it canceled any minor fault codes and the "limp home" mode, people forget that 3 minor fault codes will "fool" your car into limp home mode and the result is you take it to your nearest dealer who will reset the codes/ or place the ECU into learn mode,P.
    Member
    Sep 2006
    Milton Keynes
    0
    surely though limp home would have put the ECU light on?
    Paullyp's Avatar
    Mar 2005
    0
    not all the time, some faults will not produce a code, relays, fuse failure etc etc,P.
  5. #5
    Member
    Sep 2006
    Milton Keynes
    0
    OK.
    Well its gone back to running bad already.
    What i have noticed is that the car, when cold has a "surge-hesitate-surge" behaviour, about 1hz in frequency at a steady throttle.
    Now this dosent make a great deal of sense, as while this is what i would assume would tie in with a lambda fail, the lambda should not be talking to the ECU when the car is cold.
    Its all weird
  6. #6
    Paullyp's Avatar
    Mar 2005
    0
    Pure Volvojoy
