ok if i put my foot down the boost gauge nearly goes half way and then drops back slightly? is this what they are ment to do?
Does it feel like it's down on power and pulling back, could be an air leak, sticking wastegate etc...Originally Posted by T5-Beast
S60 T5 in Black/Dirt
ITG Filter, few HICO styling bits.
'STILL Considering' the RICA.
Not much else, yet...
have a look at this , it may help. i need to check this myself but am dreading the heat shield having had a look at it.
can you hear any whistling when boosting up.
MONDEO SPORTS FABRICATIONS
Volvo S40 T4 CD Phase 1.
eibachs,td04-16g(mapped),apexi custom induction,twin custom powerflow,100 cell race cat,twin cold feed,cold fan,17" polished rims
blitz custom boost gauge,twin piston bov,modified mk3 golf gti alloy upper strut,loadsa uprated silicone hoses,
millers cfs triple ester 10w/60.BLA BLA BLA..
gagging for rear end polybushing as its £££££e.
i can hear hissing (not a whistling more of a sucking noise - but of air flowing) and mine also goes to about 3/4 then drops back to about 1/2 way.
Easiest thing to do is stick a boost gauge on it and see whats what.
Also adam has a trick of holding the revs at 2k and if it hunts then it's likely got an air leak.
Also where you located might be a local member who can help. Edit your location in your profile.
Ac.
Have a look under the black cover where the vac pipes go to the tree..
my guess is that you have a split pipe there ( mine did )
check the bottom of the big rubber pipe that joins onto the inlet manifold they blow occasionaly
Edited my profile.
All the vacuum hoses on mine look good around the tree there with the exception of the large one which goes into the ISCV which appears to have leaked oil out over the valve. I will put a new clip on it later.
Originally Posted by wootty
can kind of, i thought it may be the turbo spooling up, on the vac tree some donut has put screws in the hole to seal them? anyone know if this may were the air is leaking? and how easy to replace?
there are caps on mine.Originally Posted by T5-Beast
sure ovlov would sell them to you for about £1 a time lol
well the things the cap go on are missing so they have just pluged the holes with bloody screws! lol
More like 100 qiud + VAT a time Lol.Originally Posted by thetroublemaker
When your bank statement says you've spent too much just think "You can live in your T5, but you can't race your house!"
that dosent make sense.Originally Posted by T5-Beast
the caps fit directly onto the vacuum tree - or at least do on mine
Mine blew a cap off, after I loosened it faffing around working our where best to install my boost gauge hose. I fixed it by looping a piece of 4mm silicon hose between two of the nozzley thingies and securing each end with cable ties. As long as it is a closed system it's fine - not given me any problems in about a year since I did it.
Swordy21
I get up every morning determined to both change the world and have one hell of a good time.
Sometimes this makes planning my day difficult.
E. B. White (1899 - 1985)
My Location
Done: (To date)
1998 V70 T5 CD.
Stage 0,
RICA ECU 310,
ITG Pro filter,
Volvo Strut Brace,
J3 Stealth Boost Gauge
Zimmerman Front (warped), Brembo Rear Rotors
PAGID Fast Road Pads
New Engine Top Mount Bush,
New CV joints,
Wobbly ABS Repair,
PCV hose running repair
where can i get a vacuum tree from?
LOL....From your local Garden Center!....Originally Posted by T5-Beast
Try Salvo, I'm sure they would have one. DB.
Saffy V70R Auto estate
Vacuum tree = '2 quid' from volvo!!!
