Page 3 of 3 FirstFirst 123
Results 41 to 53 of 53
  1. #41
    Mar 2005
    6
    Have tried them all and for me there is no comparsion with the Ferodo performance or DS2500 [also at a good price from VT] it's all right saying that you rarely need that extreme braking capibility because you drive at a steady pace but these emergencies happen as we all know.
    S70CD t5 manual w/walnut incl. steering wheel, Rica 310 ecu, K&N, switched cold spray to i.c, d/pt plugs, 302mm f/disc, s/s hoses, f/strut brace, polybushed engine mount & control arm bushes,Koni FSDs with 30mm lowered eibach springs. R front bumper, boost gauge on pillar, 17in comets.w/pilot sport 215/45/, aerial down switch, double fog intens.
  2. #42
    Mar 2005
    6
    Point taken for the DS2500 but the Ferodo Performance pad does not fall into that catagory and I have found it to be a far better allrounder than the std volvo or so called police spec pad.
  3. #43
    I have been unfaithful to
    Volvo twice since joining this
    forum but it's only for more
    than 5 pots nuf said
    lance's Avatar
    Aug 2004
    Notts
    946
    All pads are crap till they have been worn in race or standard, I never had a problem with DS performance pads and my insurance company had no problem with them either.
    2004 V50 T5 SE
  4. #44
    Engineer's Avatar
    Aug 2005
    London
    5
    My race DS2500's work fine cold on my S70R so can't see what all the fuss is about to be honest
    Engineer
  5. #45
    Member
    IC's Avatar
    Jul 2008
    1
    Interesting thread, I guess the proof of the pudding is in the eating. Gary, you don't have an issue with DS25000s - how many people have actually used DS25000s? (in addition to the people who have posted that they have used 'em so far in the thread)
    Past Cars
    '91 440
    '98 V70 T5 MTE
    '93 850 T-5
    '98 S70R MTE
    '98 S70R MTE
    '95 960
    '03 S60R
    '03 V70R
  6. #46
    Jul 2008
    Red Lodge
    11
    10 miles of pads dragging on discs = cold?
  7. #47
    Jod T5's Avatar
    Oct 2005
    Near Chelmsford Essex
    5
    Quote Originally Posted by ICN View Post
    how many people have actually used DS2500s?
    LOL, IC your a funny man.....
    It is well documented i have used these pads..I think they are great.....
    I do take James' point but i have never understood why it is ok to use these pads pre 2001 and not after..., yeah i know its the law but why?...
    Cheers
    Jod
    855 rica 304bhp, Adjusted Wastegate, Bleed Valve, ITG Panel Filter, 171k fsh, Volvo Strutt Brace, Polybush Topmount , 4mm Samco Vacuum Hoses, 10 Core "Racing" Ht Leads, 302mm Volvo Discs under 16" Columba Alloys, Performance DS2500 Fronts Red Stuff Rears, Drillled Airbox, 5w/40 Oil Changed @ 5k intervals,
    764 B230ET 108k FVSH No mods yet...Planning underway.....
    Dum Spiro Spero
    VOC 850/70 Register Keeper
    VOC 20419
  8. #48
    Al115's Avatar
    Feb 2005
    Herts
    672
    I have them on one of my T4s, they are fine. Never had them on a T5.
    Alastair
  9. #49
    Engineer's Avatar
    Aug 2005
    London
    5
    Quote Originally Posted by Jod T5 View Post
    Cheers
    Jod
    I thiink there's a thread on the VOC where we nailed this subject mate if its still there
    Engineer
  10. #50
    Member
    IC's Avatar
    Jul 2008
    1
    You're right Gary, I remember Don posting about the law regarding post 2001 cars - the VOC forum appears to be off-line at the moment due to reconfiguration.
    Past Cars
    '91 440
    '98 V70 T5 MTE
    '93 850 T-5
    '98 S70R MTE
    '98 S70R MTE
    '95 960
    '03 S60R
    '03 V70R
  11. The Following User Says Thank You to IC For This Useful Post:
    Engineer (Tuesday 12th August 2008)
  12. #51
    Jod T5's Avatar
    Oct 2005
    5
    Quote Originally Posted by Engineer View Post
    Im not sure that it ever got to the point of why the pads were restricted by law to the pre 2001...
    Still we will not know for a day or two....
    Cheers
    Jod
    Dum Spiro Spero
    VOC 20419
  13. #52
    Engineer's Avatar
    Aug 2005
    London
    5
    Cheers
    Jod
    Yeh we did amongst other things basic reason is to stop cheap imports etc. killing peeps but it also stops you using a better pad than originally fitted such as the DS2500 RACE PAD, here's a quote..........
    Requirements of 71/320/EEC Annex XV and EC Regulation 90.01 - Replacement Brake Linings
    There are requirements for the physical characteristics, braking performance and packaging for replacement lining assemblies. The replacement linings are tested against the original equipment linings to ensure that they match the performance within certain tolerance bands. Certain tests can be conducted either on a dynamometer or on a representative vehicle and MIRA can arrange for either tests to be conducted using the method chosen by the customer.
    Engineer
  14. #53
    Jod T5's Avatar
    Oct 2005
    5
    Well i think thats complete B0llox Gary.., i appreciate the need to stop cheap imports and legislation is required for this but i cannot see the reasoning behind the outlaw of pads that exceed the OE characteristics....
    Anyway im off weekend tuning.....
    Cheers
    Jod
    Dum Spiro Spero
    VOC 20419
