Hi all,
Has anyone had any thing to do with the use of Ametech engine restorer? I'm looking at using it on my V70 T5, as it increases the compression if they is any wear on the cylinder lining.
Obviously I'm going to check the compression first to see if it needs it or not. All the reviews I've read say its like magic but it seems to good to be true!
For no one who knows you add it to the oil and it apparently fill any scratches in the cylinders hence better compression.
Phill
