hi ive just bought a plitfire boost gauge and am unsure where you plum the vacuum pipe in to??any pics or advice etc??thanks
Hello baba...
(very quikcly and off the top of my head - just on my way out to work!).
I plumbed my boost gauge in to the vacuum tree.
1/. Remove the throttle body cover (sits th the right of the fuel rail).
(Black plastic cover with one torx srew securing it).
2/. Under here is the vacuum tree - black 'tree shaped' thingy with 6 or so outlets on.
3/. One or two (can't remember) should already be in use - namely for the stock boost gauge, the rest will have bungs closing them off.
4/. Simply remove one of the bungs and attach your hose here.
Sorry - no pics, perhaps some-one can post one up in a bit??
Hope this helps - must dash to work now!!!
Wish I had a Volvo!
old thread i know, but very helpfull as i'm buying a boost gauge for mine
hello mate i plummed my boost gauge into the original dash boost gauge (the black and white one) i just felt under the dash and found the vacume pipe going to the dash gauge and cut it. then put a T peice in that goes to the new boost gauge. that way you dont have to run loadsa vacume pipe through to the engine its so simple that way
y2blade (Monday 24th November 2008)
does this help?:
http://volvospeed.com/Mods/boost_gauge.htm
1998 BMW Z3 2.8 Roadster
