OK anyone whos anyone should know some prices as this weekend i am off to gns to get 1LUGS 2:LEADS 3:ITG FILTER 4IZZY CAP 5:ROTOR ARM 6:FAN RELAY 7:ENGINE TOP MOUNT 8:THERMOSTAT (87deg/97deg?) thanks everyone its not a cheap weekend this one!!
850T5-96-CD-AUTO-SALOON-mbc-drilled airbox-d/v-cbv removed and blanked off-acc rod 3 turns-21psi boost-std ecu(for now) K+N panel filter-1/4 ml times (waiting to get a time) "HELLO"from"RICH"
I've got a brand new distributor cap for you! For the princely sum of £15 all-in, I will send it ASAP if you want it. Just sent an email/message with your details.
Chris
I've just remembered I've got a brand new rotor arm also. It's missing one of it's mounting bolts but you'll be able to use one off your exisiting rotor.
£20 all-in for the two items
Sounds good to me but are they bosch items if so then yes il'll have em! ta ps anyone else got any new items going cheap(tight arse me!)Originally Posted by sizzlechest
They are not bosch but quality replacements.
No thanks only the best for my ladeee thanks though!Originally Posted by sizzlechest
It is very much quality, sir, much much quality
ok prices today are dist cap £9-Rotor arm £6.75-ign lead set (volvo stamped on em)£39.50-bosch spark plugs £4.95 each-thermostat(87deg)£6.25-rubber upper engine mount£5.95-fuel filter £12.90 hope this gives some idea,these were all bought at german and swedish,feltham
