Ok first things first you will require a small flat bladed screwdriver a piece of cloth and a torx set
Ok step 1 is to disconnect the battery and wait about ten minites for the airbag to disarm
Then open the glovebox and remove the six torx screws on the front of the insert and remove it.
Now open both doors to get to the side vents and using the cloth and the small screwdriver slowly prise these both out.
Next do the same with the speaker grills
Then the air vents on both sides
And the middle
Now its time to remove the torx screws
One from each side here
Then two from here
Two from here(top of the clocks)
And finally two from the underside of the dash in the glove box
Then its just a matter of pulling the dash forward and then lifting it out
