I took my throttle body off the other day to give it a wee clean as the car has a slight uneasy idle at random times......
Used carb cleaner and it came up all shiney like new.... I thought about the throttle switch when a was spraying away but decided it was too late now and just gave it a wee spray of WD40...
Anyhoo, stuck it all back together and fired it up..... Engine management light came on then the gearbox arrow came on and started flashing
I switched it off again and went back to see what I had done wrong....
It worked out that daft a*se had forgotten to plug the thottle switch back in....
So I disconnected the battery to reset the ECU and plugged the switch in....
Started it up again and no gearbox arrow but still got the engine management light....
I read the codes and it said PO1621 IIRC which is Transmission Control Module (gearbox ECU)
Called Mark at Salvo and he sent me a ne Throttle Switch but the codes still there.... I have reset it and it just comes back
Now the car drives fine, maybe a bit more sluggish than normal but not a lot, still boosts the same and goes through the gears perfect...
Any ideas????
