Got home from work today and decided to put an end to my clicking doors, I managed to undo the check strap on the drivers door and removed the door with no problems only to find someone has already attempted to weld where the spot welds have failed and now their welds have failed! i've left the check strap off for now.....
The passenger door proved a bugger and i'm ashamed to say i lost my temper when the torx bit ATE the inside of the check strap securing bolt... so now i'm buggered! The passenger side was the worse too, it echo's down the street every time we open the door.... anyway, i havent got a tap and dye set or whatever it is... so, what can i use? or shall i leave it to a garage?
