I understand that there are a replacement torque bushing available like this:
Anyone replaced theirs? I don't want a nasty rubber one again if you have where did you get it from and what was the price?
Bison
Bison
Yeah i could do with one of them as well mines gone too
Don't forget to check the ones at the bottom as well
Volvo ABS ECU Repair
Kalmar Union do them for £22.TOP MOUNT.
just be aware that although they will outlast the originals they also transmit a fair bit more through vibration etc to the car due to the more resiliant material and give it a harsher feel, for that reason i replaced mine with a o.e item
I don't think that will bother me as my suspension is lowered and harder than the original.just be aware that although they will outlast the originals they also transmit a fair bit more through vibration etc to the car due to the more resiliant material and give it a harsher feel, for that reason i replaced mine with a o.e item
Why replace with O.E when you can have so much better!
Bison
That is true, but I have one and love the slightly growlier noise I get... I'd say it was a "positive" rather than a "negative".
Alastair
i didn't notice any difference, but my exhaust does drown out erveything else
OK guys and girls what is the price of both items,the price differance will probably swing it for me cheers
850T5-96-CD-AUTO-SALOON-mbc-drilled airbox-d/v-cbv removed and blanked off-acc rod 3 turns-21psi boost-std ecu(for now) K+N panel filter-1/4 ml times (waiting to get a time) "HELLO"from"RICH"
Volvo Gloucester wanted £38 for OEM rubber bushing so I went for these in the end @ £23 inc delivery.
www.partsforvolvosonline.com/bushings
Look nice in Blue as well.
Bison
Yep a worth while mod IMHO
SAM ECU
Custom Super 60 18T Turbo With Uprated 300/70 W/G
Blitz Dual SBC Boost Controller
Blue Injectors
NGK Iridium Spark Plugs
Custom 1 Box 3" Turbo-Back Exhaust
TurboXS Type R-HFL
K&N Style Cone Filter With Cold Feed
87 Deg Stat
Full Poly Bushed
Custom 60mm Drop Suspension
Strut Brace
18" Shadow Chrome Pegs
305mm Drilled Brembo's With Ferodo DS Pads
6000k HID Kit
Flat Areo Style Wipers
See All The Pics Of SAM Here
I have one of these on order, Came home from Avon and noticed that the original rubber bush had disintegrated and there was only a tiny bit of it left !!!
There has been a jolt when the auto box changes up for some time and i assumed it was the box. Hopefully the new bush will cure it.
I also used partsforvolvosonline, good service and speedy delivery in the past.
DYKT (did you know that) there's another side to this mounting ? Mine was broken at the firewall side and it's more costly compared to the above mentioned. You'll have to remove the air vent/well below the windscreen to remove/fix it. Either side would give you some unpleasant noise and feel when damaged.
That side seems ok mate. Its amazing how much they charge for a lump of rubber.Originally Posted by glock19
Dead right Aiastair it sounds great. fitted mine tonight she now sounds mean as hell. the gear changes are much smoother and more instant if that makes sense ?Originally Posted by Al115
A definite thumbs up for this mod.
I have to admit I got mine from Don
SAM ECU
Blue Injectors
TurboXS Type R-HFL
87 Deg Stat
Full Poly Bushed
Strut Brace
6000k HID Kit
Hmmmmmmm I think you lot may have talked me into this......Any offers of a fitter LOL
x
I am as always, your humble servant
DAVE
SAM ECU
Blue Injectors
TurboXS Type R-HFL
87 Deg Stat
Full Poly Bushed
Strut Brace
6000k HID Kit
