Checking the levels, need some steering fluid so What fluids do i need?
Can i get them anywhere or special volvo dealer only brew?
Thanks.
Thanks.
you can buy power steering fluid from any good automotive store(i use slick 50 version with a stop leak agent in it) or you can use atf fluid as it is the same thing
SIGNATURE COURTESY OF STORM TROLL
most importantly, what year is your car.. as if its around 2000> it may not be ATF, but a special (low temp) version.Originally Posted by nurvware
brake fluid will be DOT 4 brake fluid, unless its been upgraded to DOT 5
FRF FEEDBACK (click here)
(Mon to Fri 9am to 5pm)
V70 T5 2001 Ex Plod
i wouldnt use ATF unless the liquid in your bottle happens to be red.
being a 2001 model i would guess you have the low temp PAS fluid, volvo part number 1161529
very true forgot to as how old it wasOriginally Posted by Rufe
Don't use dot 5 it's silicon based in the UK and can't be mixed with normal dot 4, dot 5.1 is the correct number.
Engineer
