does anyone know how to remove them ?????
1995 854 t5
40mm lowered
bilstien shocks
strut brace [ome] wow what a difference
poly top mount
new turbo
drop links and rod ends
bonnet wadding removed
RICA power
turob to i/c pipe hose
bcs hoses
silicone vac lines (part done)
new oe wishbones
k&n panel filter
to do
paint up v70 r calipers calipers
R bumper
my vBGarage
The key mechanism in the door handle..... or........ the locking unit that clasps the door..?
Current Garage:
*Data Sept 2013
the ket mechanism...so the handle can be delocked
or the barrel changed for one that matches the set on the car
1995 854 t5
40mm lowered
bilstien shocks
poly top mount
new turbo
RICA power
bcs hoses
new oe wishbones
k&n panel filter
to do
R bumper
my vBGarage
Have you managed to get the handle out..?
If not then loosen the two torx screws on the side of the door and lower the lock then remove a little plastic plate and undo two more screws. the handle should then come out completely....
From there I'm not sure, cos I ain't looked but there must be a circlip or something to remove and the lock should pop out...but that's only a guess...
Current Garage:
*Data Sept 2013
umm i did have a spare front door handle somewhere but could not see how to do it easily
so gave up now cant find the spare handle have moved twice since then
have a dead one on an old door so may have a play with that
1995 854 t5
40mm lowered
bilstien shocks
poly top mount
new turbo
RICA power
bcs hoses
new oe wishbones
k&n panel filter
to do
R bumper
my vBGarage
Hey there t5tart,
If u carry out this job, n u feel the inclination, I'd like a how 2 (if 1 doesn't already exist on here) as I wish to completely remove all my door handles n any help/tips n advice will b warmly welcomed!
Thanx in advance if u do go ahead with it
I am sure someone de locked their doors on hee??
1995 854 t5
40mm lowered
bilstien shocks
poly top mount
new turbo
RICA power
bcs hoses
new oe wishbones
k&n panel filter
to do
R bumper
my vBGarage
just a guess - my car is in garage so can't check - but are the front and rear handles the same except the lock? was an old trick I've seen used on mk3 Cavaliers - get a nice neat de-locked handle just by fitting rear handles on the front doors
oooooooooh now there is a thought
ill have a look
hehe
and have some spare rears too hehe
1995 854 t5
40mm lowered
bilstien shocks
poly top mount
new turbo
RICA power
bcs hoses
new oe wishbones
k&n panel filter
to do
R bumper
my vBGarage
I'd be interested to know how you get on with this...Originally Posted by t5tart
Wish I had a Volvo!
thanks mrs mopp
1995 854 t5
40mm lowered
bilstien shocks
poly top mount
new turbo
RICA power
bcs hoses
new oe wishbones
k&n panel filter
to do
R bumper
my vBGarage
