Hi.
Just wanted to know what the spec is for the C70 T5.
Whats the 0-60 time.
Whats the top speed.
thanks.
Looking to get it chipped to the 310bhp. Just feels like its not running right. or either that i am getting used to the speed. lol
Hi.
thanks.
0-60 is about 7.2 seconds
Top speed is limited to 155 but once remapped should do a little more.
x
Tech spec on the 2000 C70 (base coupe model) in addition to this
Floor pan is the same as 850 & V/S70
Wheel base - 2664mm
Length - 4717mm
Width - 1816mm
Turning Circle - 11,704mm
Drag Co-efficient - 0.29
Kurb side weight - 1546 kg
Power:
-Turbocharged 2,319 cc 2.3 liters 5 in-line front engine with 81 mm bore, 90 mm stroke, 8.5 compression ratio, double overhead cam, variable valve timing (after 1998)/camshaft and four valves per cylinder (B5234T3 Engine)
-Multi-point injection fuel system
-Main 70 liter premium unleaded fuel tank **
-Power: 240 HP++ @ 5,400 rpm; 243 ft lb/329 Nm @ 2,700 rpm
++Though my latest put down 242bhp at the wheels (untuned) at the last dyno day.
**I've never managed to squeeze any more than 65 litres into mine.
Transmission
5 Speed Manual or 4 Speed automatic with switchable sport/econ modes.
Handling
ABS
-Four disc brakes including two ventilated discs
-Immobilizer
-Spacesaver steel rim internal spare wheel
-Strut front suspension with stabilizer bar independent with coil springs , multi-link rear suspension with stabilizer bar semi-independent with coil springs
- 16 or 17" alloy wheels - pcd: 108 x 5
- 17 inch standard tyre size - 225/45/R17
Interior specs do vary from Base model, GS and GT (confused/fudged by optional extra & delete options)
You will become accustomed to the power - everyone does to a greater or lesser extent. Look through our Stage 0 tuning to ensure that your C70 is running as well as it can.
Hope this helps.
Volvo ABS ECU Repair
Thanks for the great replies.
I suppose i am only saying the power feels down sometimes, as its a auto and find if i dont get it right it takes a little while to pull off from low speed. once there is goes like hell.
will look into the stage 0 bits.
cheers.
tony
