Results 1 to 17 of 17
    Dec 2005
    chorley, lancashire
    0
    advice on modifications
    ive got a 96 t5 estate auto with 102,000 on clock, what modifications can any one recommend as i use it everyday want to keep the reliability and if so fuel consumption or get better that would be great,also would a larger downpipe increase fuel consumption (and is it worth doing) any advice would be great. thanks
    Member
    Aug 2004
    73
    A 280 remap will fit the bill perfectly - no other mods required
    x
    Member
    Mar 2005
    I live in Sweden, Eskilstuna to be precise.
    0
    Hi there. You can also use the 850 GLT camshafts, both the intake and the exhaust cam. This gives you the advanatge of the GLT´s high rev power, and the turbos low rev power.
    Your engine will give more power on the high rpm´s. This also means that it will not drink more fuel when driving normaly. But you have the extra when you want use it.
    Best glt camshafts to use is the 92-94 once. I use the -92GLT camshafts in my -95 850 Turbo.
    Best regards// Peter Larsson
    arbee
    Guest
    Quote Originally Posted by S60T5
    Hi there. You can also use the 850 GLT camshafts, both the intake and the exhaust cam. This gives you the advanatge of the GLTīs high rev power, and the turbos low rev power.
    Your engine will give more power on the high rpmīs. This also means that it will not drink more fuel when driving normaly. But you have the extra when you want use it.
    Interesting that - never heard of this before - Anyone else tried NA cams over here?
  5. #5
    Member
    Aug 2004
    73
    Quote Originally Posted by arbee
    Interesting that - never heard of this before - ?
    In was thinking the very same!! Hmmmmm......
    x
  6. #6
    Casual poster 15 years on!
    Murphy's Avatar
    Oct 2004
    Derbyshire
    100
    I have a 850 2.5 GLT - can i just bolt a turbo on then ?
    My TWITTER username
  7. #7
    pault5's Avatar
    Sep 2004
    69
    hi,
    i think some people on the volvospeed forum in the usa have used this mod.
    paul.
  8. #8
    volvotuning's Avatar
    Oct 2004
    0
    And in Europe, including UK.
    Adam.
  9. #9
    Al115's Avatar
    Feb 2005
    Herts
    672
    I've heard quite a lot of talk about using NA cams, from over the pond.
    Alastair
  10. #10
    this member hass no status
    thunderace's Avatar
    Jun 2005
    Doncaster
    31
    Blimey Murphy, it's still running then?
  11. #11
    Junior Member
    nick790's Avatar
    Jun 2006
    0
    Would the GLT cams have any advantage over my 850R cams??????
    I thought the 850 R's had slightly wilder cams than the T5's?
    Interesting thred.................
  12. #12
    arbee
    Guest
    Quote Originally Posted by nick790
    as far as i know the R and normal T5s did not differ in terms of cams but I may be corrected
  13. #13
    If in doubt thrash it and see
    what happens
    woz's Avatar
    Mar 2005
    Bristol BS5
    58
    recommend going up to Volvo tuning (VT) and getting the 280 remap -speak to Adam /hamish about any extras e.g. downpipe etc.
    My thinking says lower backpressure = lower consumption. More power is a by product - but speak to the experts. Only a rolling road will tell.
    Its an economincal upgrade and my consumption is a little better than a standard motor provided I dont thrash her little cams off! But the driveability is something else and you can just get away with 95RON fuel!
    Have fun.
  14. #14
    pault5's Avatar
    Sep 2004
    69
    hmmmmmmm
    found this on the qbv site.......
    http://www.quickbrickmotorsports.com/prod_camtool.html
    paul
  15. #15
    Dec 2005
    chorley, lancashire
    0
    briliant guys thanks, i will give vt a ring next week see what they can reccomend . thanks for all the info.
  16. #16
    what happens
    woz's Avatar
    Mar 2005
    Bristol BS5
    58
    Thanks Paul - found this before and lost it. been loooking for it today. Nice one!
    Want to discuss with the guys at Volvotuning see if they rate the tweak r do it anyway.
    Cheers
    W:>)
  17. #17
    Member
    Mar 2005
    0
    Hi Nick.
    The GLT or N/A cams will have an advantage over the camshafts you are using right now.
    Why??? Easy, do a test drive of a Volvo 850 GLT from lets say -92...
    That car is rather dull, right...
    Wrong... Or almost... In the lower revs that engine is not to much to write home about, but in the higher revs that engine is rather quick...
    With the N/A cams your engine will give you the extra thrust between 3500-4000 rpmīs and up till you put your clutch down. You donīt have to remap or alter anything else when changing your camshafts. Therby itīs a rather cheap way of improving your cars action when you want to use it in the higher revs. It still goes like normal on the lower rpmīs.
    And beccause of this you will not change the mpg for your car. (Unless you get a kick of using the higher revs... But then again, who doesnīt)
    I think you should go for the remap, as said earlier in the thread, the N/A cams, 3" downpipe and exhaust from the dp to the cat (2,5" from cat and back), and maby some new brakes
    Price on a set of used glt-camshafts here in Sweden is normally around Ģ120-130. New once... I dont want to know...
    I donīt remember who said that they would turbocharge their glt instead...
    Personally I think that itīs cheaper to buy a set of used camshafts instead of buying a turbo, intercooler, ECU, gearbox, brakes, driveshafts, and so on...
    But hey... Thatīs me...
    Not a good thing to convert the N/A to a turbo, to much things need to be changed. (Iīm not saying it will not work... It will, I know... But not that well)
    Best regards // Peter Larsson
