This is what Meg's said about my car
Meguiars Car Care Guide:5232
Especially Prepared for: Wobbly Dave
Vehicle: Volvo C70 T5 1999 WHAT YOU TOLD US
Your Paint: Undercover - Never
Paint Condition: Light Colour Original Paint New/Like New
Appearance Goals: Absolute best all of the time
Time Goals: Whatever it takes to make my car look its best
Noticeable Imperfections: None Tree Sap Fine Swirls Stains/Blemishes Bugs Heavy Swirls Water Marks Road Tar Scratches Industrial Fallout Overspray Bird Droppings Oxidation/Fading
The information you have provided helps us advise you on the best way to take care of your paint finish. Please ensure you also read the label information on the bottles before using products.
Wash
Why this is prescribed...
Regular washing with a non-detergent, gloss-enhancing product will help preserve shine and maximize the life of the wax/polymer sealant coating. Mass market washes claim they won't strip wax but they do.
What to Use...
You can safely & easily remove dirt, grime and fresh contaminants using MEGUIARS GOLD CLASS WASH.
The advanced formula has special conditioning agents that leave the paint finish so slick that the water actually sheets off. Apply using a soft sponge or wool mitt.
Frequency...
Since your car is often exposed to the elements you should wash it every week as contaminants tend to get baked on very quickly.
Note:If you notice some contaminants aren’t being removed when washed, try increasing wash frequency.
Surface Prep.
Even though your paintwork is in new/like-new condition, it will still need a surface prep step to correct the imperfections you told us about and to maximize the clarity of the finish.
What to Use...
Most of the problems you described can be safely removed using MEGUIARS SCRATCH X which is a mildly abrasive formula that's totally safe for prepping a new/like-new finish. However, baked on contaminants and some swirls, scratches or etch marks can be difficult to completely remove. Scratch X will dramatically improve the finish. Apply using a Meguiars Hand Applicator Pad, then wipe-off with a Meguiars Ultimate Wipe Cloth to avoid any surface scratching.
Frequency...
You will only need to repeat the process if & when the same problems reoccur. However, since your car is often exposed to the elements, you may need to use MEGUIARS QUIK CLAY occasionally to remove bonded surface contaminants.
Polish
You told us that your are looking for the best possible finish, however since your car isn’t a dark colour you can achieve maximum results without needing an individual polish step.
What to Use...
You can use one of our unique formulations that will polish & protect in one step.
Protect
Polishing oils bring out colour & shine and Waxes keep the finish that way, by protecting it from the elements. Our special one step polish & protect formula also enhances wetness of gloss & shimmering effect.
What to Use...
To bring out the full richness of colour and create clear, sharp reflections while adding long lasting protection, we recommend MEGUIARS GOLD CLASS WAX.
Apply using a Meguiars Hand Applicator Pad, to the entire car and allow to dry to a haze. Wipe off with a Meguiars Ultimate Wipe Cloth.
Frequency...
Considering your time & appearance goals and the fact that your car is often exposed to the elements, we recommend you reapply every 2 or 3 months.
Maintain
Since you're very particular about your vehicle looking its best, this will help you keep that "just waxed" look in between washes.
What to Use...
To safely & quickly remove dust, grime, waterspots, fingerprints etc & keep you car looking sharp every day, you should try MEGUIARS QUIK DETAILER. Simply mist on then wipe off with a Meguiars Ultimate Wipe Cloth anywhere, anytime
Frequency...
Use as often as you like in between washes.
