Hello.
I am thinking of buying a 850 T5 Estate. Ive got about £2000 to spend.
Could any one tell what I need to look at and check before purchasing.
Thanks for your help.
M
Hello.
M
Hi mate right there is the obvious things like bodywork service history tyres and so on other things are when you go and look at one make sure its cold when you first come to start it if it is get the seller to start it while you stand at the back to check for any blue smoke,check to make sure the lights all work on the dash and the abs light goes out as it should,if you can check the under neath look at the exhaust/cv boots and steering rack boots,then go for a test drive if you are going for a 850 make sure when you give it some that the boost gauge in the dash goes about 3/4 into the white give it a couple of good blips on the throttle when driving(goto about 6000 rpm) then take your foot of the gas give it a couple of seconds or so then give it gas again look in the mirrors for smoke!!!!.After the test drive try to leave it ticking over for about 5 mins and then blip the gas again for smoke.No doubt i have missed something and someone will probably help out with some more info
Regards
Wayne
SIGNATURE COURTESY OF STORM TROLL
Cheers mate. I have noted it all!!
Does the aircon work?
Rear oil main seal - is it leaking
Sean
What T5ER said, and yeh check the air con.
03' S60 R
96' 850 T5 (gone but not forgotten)
Just before you worry all cars emit a lot of steam from cold until the cat has warmed up, esp on damp mornings etc. Any blue smoke = oil and ultimately turbo (if excessive) or valve stems(if slight at startup and tickover), any brown smoke = bad fuel/air mixture. Any steam is perfectly healthy, but this should reduce as soon as you move off.
Check under bonnet as well, oil on top of the oil filler area is fine (just a gasket in the oil filler cap) and the o ring on dipstick are common but dirt cheap fixes. Look around the dizzy for oil (not fatal or worrying) and check all hoses.
Do you want Auto or Manual?
Thank you very much. Im on the case!
I really wanted a manual!
Auto is so yummy thoOriginally Posted by Matt
03' S60 R
Is there much difference in MPG, how reliable is the auto box?
I had an 855 T5 auto, i did a lot of inner city work. Averaged 18 mpg. On a holiday to France (1500 mile return) it went up to 24 mpg [a/c on all the way]. The manual averages 24 mpg, so yes the auto takes more fuel. I think a gearbox will last 150+k depending on use.Originally Posted by Matt
My TWITTER username
If i drive my Rica'd manual fairly quickly around the twisties i average about 17 mpg. I drove it today in grandad mode as i had to put normal UL in as an emergency. At legal speeds on coutry roads i got 28mpg. If economy is an issue i wouldn't look at buying a T5.
Mine does 21.3 mpg and i often toe it up the M1 from jct 4 to 8 approx 15 miles. I also take the scenic route some days but it pretty much never moves. Mine is also on 168k and (touchwood) gearbox seems fine, although after the turbo going on me last week im gonna start a "new gearbox fund".
03' S60 R
