M B C I NEED HELP! WHERES BRACER!OR VOLVOTUNING PLS HELLO TO ALL im trying to fit my m b c and dont know which pipe/hose to plumb into CHEERS RICH
it goes in the pipe going to the actuator from the boost control solenoid (mounted on the air box with 3 pipes going into it)
SORRY MATE i really dont now my turbo very well could you explain where both ends go to cheers RICHOriginally Posted by Pedro Fandango
Do most people run the MBC and the boost control solenoid at the same time? Or have I just read this wrong.
On Jacqs we disconnected the boost control solenoid from the actuator and vaccuum tree, and the MBC is fitted in its place. I know there are some people who leave the solenoid fitted if it is remapped, with teh MBC used to spool the turbo up faster, but I got the feeling this was intended just as a replacement controller to increase the boost in this case?
Ross
it might be easier to explain the way i've done it then.
On the side of the air filter box you'll find the BCS (boost control solenoid, a black box with 3 pipes going into it) follow them back from the solenoid & you should be able to see 1 connected straight to the turbo, 1 going to the air intake pipe (after the maf sensor) & the other going to the back of the engine by the turbo but dissapearing under the heat shield. The pipe from the BCS to the air intake take off the solenoid & block up the end (i used a screw), the one from the BCS to the turbo again take off the solenoid & put on the input side of the MBC, the last one on the BCS (going under the heatshield) take off & put to the outlet side of MBC. Don't un-plug the BCS you'll still need it wired up to keep the ecu happy, even tho you've got no pipes connected to it & its not actually doing anything.
hope thats clear enough for you, & be very careful what boost you set it to
Ahh, yeah thats what was done in in Jacqs T4, I just picked it up wrong in the first post.
As Pedro said, a boost guage is a must in order to keep an eye on what you have set it to, very easy way to blow your engine up is an MBC lol.
Ross
YOURE A DIAMOND ive looked around and 14.5 seems to be the limit yeah? cheers PEDRO RICH
ALSO THE BOOST GAUGE IS AN AUTOGAUGE LUMINESCENT BOOST/VACUUM IS THIS OK OR NOT (ADDITIONAL INFO VACUUM ON TICKOVER IS -20 FULL BOOST IS 8/9 AND DROPS BACK TO 6 BUT WHENIT CHANGES UP IT SPIKES TO 10/11 WHATS GOING ON? cheers RICH
to be on the safe side i'd set it a bit lower than that, 14.5psi is about where the ecu shuttings the igniton down for a split second because of excess knocking (when using decent fuel, it will be a lower psi if your only using 95ron)Originally Posted by rich850t5
believe me even if you set the MBC to the the same psi as standard you'll still be impressed because the pick-up is just so much better
tbh in the first describtion i did actually mean just cut the pipe from the BCS to the actuator & fit the MBC inline with the solenoid (but thought i'd explain the way i've done it while i was bored)Originally Posted by Ross9
Im Getting Me Torch Out
NOW YOU'VE GOT ME ive cut both pipes off the solenoid put the one going to the wastegate to the outlet and put other pipe on other end run it and it is screwed all the way in and it reaches 13psi dropping back to eleven RICH
you'll still get spiking with a MBC, mine goes upto 21psi then drops to 17.4
did you block off the pipe to the air intake?
Yeah put bolt in with silicone sealer on threads,By the way i had to reverse the order of connection as your way didnt work according to the very small description i got with it i needed to swop it round thanks for all your help PEDRO wow what a difference cheers RICH :Originally Posted by Pedro Fandango
yeah but it (MBC)is screwed all the way in and only reaches 13psi RICHOriginally Posted by Pedro Fandango
the only way i can think to over come that is put a higher tension spring in there, but tbh how much more do you want to go?Originally Posted by rich850t5
so your iimpressed with the outcome then?
lovin it every thing you said came true.However regarding the boost yours goes to 21 why wont mine do i need to adjust the acctuator rod(this i do know how to do)I would like to get it to just overboost then turn it down till it runs fine or am i dreaming and need a new turbo(sorry just thought i should tell you it will peakat 13 then drop back to 10/11 could it be the gauge it an autogauge I JUST WANT THE STD GAUGE AT THE END OF THE WHITE IVE STILL GOT 3 MM TO GO) cheers to all for your help cant wait for a meet now! RICH IM LOVING MY
tbh i've never managed to figure out why BT is boosting to 21psi, standard ecu's normally hit overboost around 14.5psi. Personally i wouldn't touch the actuator rod & just use the MBC for all your adjustments.
i very much doubt you've got a dodgy gauge, i suspect you've got an air leak somewhere (time for a stage0 tune)
got that planned for the wkend cheers again RICH
Sorry I missed your post, I've been away for a while that why.
Are you all sorted now ?
Steve
SAM ECU
Custom Super 60 18T Turbo With Uprated 300/70 W/G
Blitz Dual SBC Boost Controller
Blue Injectors
NGK Iridium Spark Plugs
Custom 1 Box 3" Turbo-Back Exhaust
TurboXS Type R-HFL
K&N Style Cone Filter With Cold Feed
87 Deg Stat
Full Poly Bushed
Custom 60mm Drop Suspension
Strut Brace
18" Shadow Chrome Pegs
305mm Drilled Brembo's With Ferodo DS Pads
6000k HID Kit
Flat Areo Style Wipers
See All The Pics Of SAM Here
