Stunning job that DD, thanks for the write up - love your plastic printing work too :)
Printable View
I've just got one issue at the moment which is sometimes it won't start first time, it always starts second time. Though I think I know why, I've just got to change the setting and test it.
No probs I'll send it over once I've worked that last issue out, it will be good to get another tester to see if it's just a fluke.
I was also looking at modifying the later model awd/2.5 ecu binary to see if any improvements can be made as the ecu in my car was from a V70 AWD and originally was the 609 binary.
DD i’ve been reading this thread with interest, very impressive! I love the the little motronic 4.4 display that you have, can it rear boost pressure and air inlet temperature?
I’m after something similar as I have an m4.4 ecu. You don’t remember what its called or where to find one do you? Was it complicated to install and program?
Thank you mate, I love doing these little projects, keeps me busy.
Motronic 4.4 doesn't have a pressure sensor as standard, you have to add one to the ecu and modify the software to log the boost pressure.
There is an intake air temp sensor on the x70 range but it takes the temperature from the front of the car so outside the intake system.
Unfortunately the display is home made using an arduino prototyping board and a generic TFT display. It plugs in to the OBD port so not had to install. The code is all my own work, using the simple arduino language.
Wow, can't believe it's been over 2 years since the last update on this thread.
Unfortunately not a lot has been done to it. I still need to remove the entire rear suspension and fuel tank to refurb them. I did change some bushes on the rear but they are so awkward to do it's best done with the unit outside the car I guess. Will have to wait for the warmer weather :)
Some time ago I purchased an S60R exhaust manifold so I decided it was time to upgrade and change the turbo turbine housing to an angled outlet. I managed to get a cheap used turbo with a 3 inch angled outlet.
Problem was I needed to change the downpipe and 3 inch flanges are expensive and not readily available so I purchased some 10mm stainless plate and made my own.
https://i.imgur.com/c11f004l.jpg
https://i.imgur.com/VcLp10tl.jpg
Then I bought some 3 inch stainless bends and started mocking up the route around the angle gear.
https://i.imgur.com/Uob7SIJl.jpg
https://i.imgur.com/5F0uPLxl.jpg
I've only got a MIG welder so purchased some stainless MIG wire and ended up with this. Not too bad I guess, the flange warped a bit due to being stainless so learned a bit from that but I flattened it the best I could and purchased the 3 inch downpipe seal used on the later cars.
https://i.imgur.com/OACgGsFl.jpg
Did a bit of porting on the turbine housing
https://i.imgur.com/szmOk0xl.jpg
Added a 3 inch 200 cell cat and fitted it to the car.
Engine/turbo now runs/spools so much better.
Only issue now is the turbine housing has a crack in it :( So the next upgrade will be a TD04HLX housing and 9 blade wheel :D :D:
Attachment 33239
https://www.google.co.uk/url?sa=i&ur...AAAAAdAAAAABAE
Recently changed the handbrake shoes only to find the O/S handbrake cable was stuck. The AWD cables have a flaw in the anchor point to the wishbone, the the outer cable wears on the cable clip and lets in all the dirt. Really badly designed unfortunately.
Nice job Dave, that downpipe looks awesome, not the easiest of jobs to do with the added issue of the angle gear being in the way.
Nice work!
So jealous of you guys that can fabricate things :B_thumb:
I was quite impressed with it myself, I even made that support bracket, looks exactly like the original (just a bit longer).
The other side of the flange doesn't look the best unfortunately, hard to weld with MIG neatly in such tight spaces (that and I'm an amateur).
I've only got basic tools; a 30 year old Clarke MIG welder, an angle grinder, a bench drill with step bit, a die grinder with carbide bit and cellotape. That's all I used.
