Just thought I should really change my o2 sensors too, originals are getting on for 120K, where did you get yours Harvey?
Printable View
I got it from Volvo , The main reason was when I got a price from them they said there are 3 different pre cat sensors and 6 post car sensors didn't bother with post cat as that's just for info to say they cat is working .
Did look at ipd site which did give a bosch part no but it says only 1 type for petrol cars 2001>
This is a photo of the one I got did try to cross reference it but nothing comes up except a Volvo part number.
http://i1168.photobucket.com/albums/...ps9jzdaknx.jpg
Yeh, I got part numbers 8670276 and 9487147 - but think they are both BOSCH 0258007137 , yours is stamped with a different number, so bit confused now
http://www.ebay.co.uk/itm/0258007137...sAAOSwdj9XTlGn
Well service due next month so got some oil from Opie oils as was on offer.
Fuchs Titan Race Pro S 5W40 Fully Synthetic Engine Oil is a Ester/PAO based full synthetic motor oils formulated to give maximum margins of protection during periods of fast road or competition use.
http://i1168.photobucket.com/albums/...si6rims6n.jpeg
Best bit Don has told me exhaust bits should be with me in 10 - 14 days :)
Hi Harvey,
My toe bars are bent like yours was. TBH can't recall if I ever did hit them. Just wondering if its worth the extra mile over the stock bars... and if there is an alternative as it seems these are no longer available from IPD.... :(
http://i1168.photobucket.com/albums/...psuzqlhjnp.jpg
Yes strange, Have ipd removed then or just out of stock at the monent?
But they don't have much strength to them as they are very thin you would think they would be a bit stronger but it all adds weight I guess.
I've been doing extensive research into this lately, due to the part numbers not correlating and being different each time I speak to a supplier.
Basically, with regards the REAR O2 sensor, there are two different types of Bosch sensor listed for B5254T4 engines.
Rear (post CAT) - 0258 006 682 is 770mm long 4 wire
Rear (post CAT) - 0258 006 488 is 1060mm long 4 wire
Both are correct application and same plug fitting.
The FRONT O2 sensor is:
Front (Pre CAT) - 0258 007 137 is 1180mm long 5 wire. (Only 1 listed)
PFV sell the sensors and the front is PFV908215.
Hope this clears things up :biggrin:
good stuff, cheers Lee
Couple more bits to fit , Just to get some nice clip tho.
http://i1168.photobucket.com/albums/...psgnthpu0t.jpg
http://i1168.photobucket.com/albums/...psm33jfmma.jpg
http://i1168.photobucket.com/albums/...psw6z14ded.jpg
do88 has nice clips ;)
Thanks Tim!
We've used proper jubilee clip to secure the factory pipe onto the ETM, when replaced the PCV & the do88 pack also contains a proper jubilee clips.
Yes all fitted and it was a easy fit , as it's size is spot on..
http://www.vpcuk.org/forums/showthre...l=1#post806654
The clamps I've ordered are these ones.
http://www.ebay.co.uk/itm/252185235886
