I hear it makes a healthy 140bhp ;)
I blame smithy it was his fault I started all this and now jks is on here I think things may progress rather well :)
Printable View
Time for more updates: these are grouped into topics rather than in work carried out so pics may jump around a bit.
I did my usual research before carrying out any work and all info is sourced from various sites.
This is by any means the only way to fo it but just an option that I chose.
Crank case ventilation / Pcv breather:
All engines produce an amount of blowby, turbo engines more than n/a and a high mileage engine more still.
On a higher mileage engine or if boost levels are raised the volume of blowby increase and the stock breather will become inadequate.
This can result in an increase in crank case pressure resulting in weeping/ blown seals.....cam seal, distributor, front and rear crank on the redblock engines.
Also the velocity of the blowby increases the ability of the stock breather to seperate oil droplets from the vapour becomes ineffective resulting in oil being sucked through to the intake and intercooler.
when I first bought the 940 I had to change all the leaking seals and buy a new pcv breather box.
This was the state of my intake:
http://i856.photobucket.com/albums/a...ps58edb8f5.jpg
http://i856.photobucket.com/albums/a...psb9e2f970.jpg
My way of doing things:
Adding a catch can into the system allows extra removal of oil droplets from blowby and also has an effect of incresing the systems ability of coping with the extra volume of blowby.
Increasing hose size can also assist in improving flow of blowby from the breather, slowing the crank case vapour down also allowing better oil seperation.
I decided on a mixture of several options.
first off I added an extra 16mm or 5/8 hose tail to top section of the pcv breather box.
http://i856.photobucket.com/albums/a...ps6077da0b.png
So I now have 2 16mm hoses from the pcv, increases volume of ventilation. These run to a 5/8 Y and into one of the catch can ports........nothing special just an ebay special.
http://i856.photobucket.com/albums/a...pse70f9521.png
All fine then? Well no cause its just an empty can....mmmm, no baffles or anything to help with seperation.....bugger.
Another quick search and found cheap way to add a basic baffleish contraption. Just needed some copper pipe and a filter.
http://i856.photobucket.com/albums/a...ps77e4c2b0.png
moves incoming vapour away from outlet so just need some filter medium.
http://i856.photobucket.com/albums/a...ps9a032999.png
just used some stainless pan scourers. Wrapped round pipe to allow capturing of oil droplets.
Its a bit heath robinson but hopefully should work.
As this is my daily driver and do mainly start stop driving I connected the outlet back to the intake, including the 4mm take off to intake manifold with introduces vacuum at idle, should stop seals blowing.
I'll see how it goes.....I could vent catch can to atmosphere using a venturi effect from exhaust to introduce a vacuum but dont want to drip oil everywhere and dont necessarily feel the need to at this point.
Well thats that so far......may have done it all wrong but its all new to me so this is another learning experience.
Cheers for reading through the usual wall of drivel ;)
Got the new radiator fitted but found in final fitment the npr intercooler just fouled the top of the airbox.
Mmmmm....bugger.
Again probably totally worthless but my way round it was to modify the airbox so it could still be used as a heat shield and use a cone filter inside.
I cut the front panel out from the airbox that directly sits behind the headlight to allow for the extra length of the cone and also access to lots of Incoming cold air.
The 940 already has a cold air feed which runs through wing into air box, works much better when you remove the tapered restriction.
Removed the front lip of the lid to allow more space round the cone filter. Also opened up the hole for filter to amm pipe and put a decent size in there instead of the ovalised standard hose, possibly less restriction???? Who knows but the silicon hose does look better.lol
http://i856.photobucket.com/albums/a...ps4a8eb839.png
http://i856.photobucket.com/albums/a...ps38c341e7.png
So I'm hoping I've stopped some of the heat soak while standing but still allowed for a decent airflow when ragging it.
Plus it was free.
First off big thanks to m-r-p and jamesy12345 for allowing me to use them as guinea pigs and put up with my endless messages.
Also to jks for his outstanding technical knowledge......big thumbs up guys.
Onto a bit of bling....yay.
Paint is cheap so thought I'd carry on giving the old girl a freshen up.
Heres a reminder of the day I bought the old girl.
http://i856.photobucket.com/albums/a...ps8d506d6a.jpg
Stage 1:
Just painted several bits: airbox lid, intercooler hard pipes, slam panel, coil. I like the white clean and simple.
http://i856.photobucket.com/albums/a...psaf78e3dc.png
http://i856.photobucket.com/albums/a...psc5163e1a.png
Stage 2:
This is m-r-p's fault but something was missing....mmmm, good idea fit some white vacuum lines.
http://i856.photobucket.com/albums/a...psc650acfd.png
http://i856.photobucket.com/albums/a...ps890ec9de.jpg
The large clear reinforced lines are for the catch can....will change them in due time but will allow me to see how the crank case ventilation is working. Still needed to tidy up the hose routing and secure them but you get the idea.
The rocker cover well that is a surprise.....learnt loads and had to strip and repaint it 3 times to get what I wanted but hopefully some of you guys will like it ;)
Next updates coming soon :)
Very nice work mate, as long as it has more than 140bhp your laughing :)
coming along nicely,great transformation in the engine bay
Black n white - you know it's right :D
Bout time those pics went public mate, looks awesome.
Cheers guys :)
Filled up with fluids now, turned over without coil connected and couldnt see any leaks or strange noises.
Fingers crossed......
Once running will be straight into 3"exhaust, poly bushing frontend, dual bars on the rear plus accumulator mod for the auto.
In the mean time gonna collect parts needed for a future t3/t4 hybrid upgrade.
Not going huge as still auto so .48 cossie hotside and poss 50 trim t4.
3" maf needed and suitable injectors.
Also downloaded some xdf and bin files so can have a look at playing with lh2.4 on tunerpro.
all good stuff....:)
So as she stands including purchase price maybe spent £500 tops at this point......and thoroughly enjoyed it.
its a swede and proud!!!!!
What do you guys think to this.......took me a few attempts but I'm happy.
Just need to do a few finishing touches.
http://i856.photobucket.com/albums/a...ps9eadfda3.png
Tonights update......
YAY......new bpr7s fitted doubled checked everything and the old girl struck up straight away.
settled down quickly to a nice steady idle.
Only ran for a few minutes got to cure exhaust manifold paint.
dont seem to have any drips but will run for longer next time. I did have to slacken off waterpump and apply bit more upward pressure to seal to head but that seems fine.
God I am so relieved. ......I was dreading today, thought I'd maybe messed something up and have to strip it all down.
Bit long winded and its took 7 pages of this thread but I've now done my first ever head gasket change.lol
big thanks to everyone thats helped along the way, wouldn't have got this far without you :)
http://i856.photobucket.com/albums/a...psdatn6kus.jpg
http://i856.photobucket.com/albums/a...pshgwfnk93.jpg
Looks very nice mate you need to do a spec list now of what you have fitted .
Well done fella, been watching this come together, love the painting job on the rocker cover! Keep up the good work :)
Still starts fine, idles well.
I have run through idle set up and tps as I'd had all the linkages off.
Heaters blowing hot air and system seems to have bled itself.
Also theres no dancing oil cap if I rest in on. So no positive pressure, so seems that changing valve stem seals has worked.
Will be booking her in for mot very shortly :)
Looks great that cam cover, fella, like we talked about
Love the level gauge on the catch tank btw
looking good that matey!
Nice work, pleased to hear it's running well after the time and effort you've invested in it :)
Nearly ready for mot.......been using a private road at back of house to run the 940 up and down.
I didnt know if the 350cc injectors would make the car run rich and fail emmisions so tried to give lh enough time to re-learn.........still running at 7psi at this point but definately got more urge than the 13c did at 12psi.......so 1psi increase approx 6bhp........mmm should be a healthy increase at 14psi upwards :)
Ran through faffing about setting up idle and tps again. Had to strip down washer pumps as siezed. New wipers, but thats all I've found to attend to.
Did have concerns about the fuel pump. Does sound quite noisy so really wanting to change it very soon.
Found out that volvo pump approx 120 l/hr, divide that by 0.47 for turbo application will support 255bhp. So thats obviously new, so a 250k mile pump would struggle to cope with even my mild upgrades.
Any recommendations on an uprated pump to use? most common seem to be Walbro 255. Are they an easy installation?
Quick check, 255 l/hr divide by 0.47.......should support approx 540bhp. So plenty big enough.
3 bar fpr o.k for the time being but might connsider adjustable regulator for future mods if its worth while.....again need your advice.
