Which one of you are running a boost controller? Are they any good & if so what sort of advantages do they give & how much should I be paying for one?
Ta. :wavey:
Mac
Printable View
Ta. :wavey:
Mac
Hi Mac any mbc thats made of brass will work well mine is comfortably running 13psi now was 6/8psi before,The guys/gals on here seem to prefer the inline type -----------halfrauds sell them at around £16Quote:
Originally Posted by macV70R
MAc are you ME7?? If so then you wont be able to fit an MBC!
x
YEAH moppys right i forgot about that
think i'm bosch 4.4 but not 100% sure...its a 97awd. It was on the computer yesterday & i'm sure it s that!!
Mac :nutkick:
If im not mistaken ME7 is 99 onwards, I think the easiest way to tell if your unsure of the year is whether your car has a throttle cable, if so its pre ME7 however if its electronic throttle then its ME7.
def bosch 4.4
Get your downpipe and race cat and get an MBC on then!
ok then...
down pipe first then mbc then re map & I'm done...
Mac
Just do the downpipe with race cat and uprate the rest of the exhaust to 3' front to back, get a new panel filter and a full service and get it re-mapped, you have the turbo that most people change to fitted to your car as standard.
Im sure once the re-map is done the mbc is of no use because the re-map puts the engine on the safe limit were boost is concerned, running an mbc aswell and upping the boost further would probably bend a rod in the block which isnt a good thing!
ok mate.
Thanks for the advice....I will sort out the exhaust first & see how we go.
Mac
