i used one of these on both my Volvo's: http://www.ebay.co.uk/itm/Car-Bike-B...EAAOSw91NTs-0I
done in 5 mins max, just remember to have a cloth handy when disconnecting
Printable View
Yes the pressure bleed kits are very handy I remember one t5 clutch I did I ended up using a vacuum pump in the end to.pull ot through they car be a rite ££££ some times
I've got an air compressor one now just incase
I can recommend the pressure bleed kit too. In fact the screw cap broke/snapped on mine so I got in touch with Gunsons (or the company that owns them) to buy a replacement and they sent me one for free!
Front splitter design all sorted, just another part that will need filling, sanding and painting when I start work on the body.
http://i170.photobucket.com/albums/u...206_121509.jpg
http://i170.photobucket.com/albums/u...206_121517.jpg
http://i170.photobucket.com/albums/u...206_121523.jpg
http://i170.photobucket.com/albums/u...206_121534.jpg
http://i170.photobucket.com/albums/u...206_121539.jpg
Where will it all end lol not bad for home made tho
Dropped the splitter down by 50mm.
http://i170.photobucket.com/albums/u...212_145037.jpg
http://i170.photobucket.com/albums/u...212_145043.jpg
Did you sort out the clutch issue Colin?
Fingers crossed for you, looking forward to seeing it propelled down the road from both ends!
Nice colour :)
Just hope you never use it .Good job. .:) ( the roll cage that is )
Supercharger bypass pipe welded onto the front mount intercooler and cooper s bypass valve fitted, but open to atmosphere, so just a big dump valve (but with more control)
http://i170.photobucket.com/albums/u...217_122802.jpg
http://i170.photobucket.com/albums/u...217_122835.jpg
No progress to report, but I do now own two M4.4 ECU's both with GT30 base maps on them, so should be a nice starting point :)
