http://i573.photobucket.com/albums/s...ps3cd03646.jpg
Printable View
I'm quite jealous of the price you paid for this...... looks quite clean. Been after trying to get the rear bench heated on mine.
Hopefully you can get it sorted and running properly, I'm trying to get a 16t for mine, might pop out on wednesday if you're out, The ph1 v70's will be taking over tpark lol
It owes me 500quid with a full tax and test. Could run it for the year and it would still be worth that. Yeah ill prob be out mate
http://i573.photobucket.com/albums/s...psfff2406f.jpg
This is the light that causes me problems.
Brake failure warning isn't it?
Dodgy sensor somewhere? I thought only plod cars had the pad wear sensor... hmmm.
ABS sensor somewhere?
Check your brake fluid level, mine flashed up at me on the strip at Shakespeare, because it was on minimum.
Wont this have the ABS rings on the driveshafts? make sure they are intact, i think its passenger side that picks up the signal for the speedo :) IF not like Mr P said ABS sensor
Its had new discs and pads and the codes reset will check the fluid if not will have to look into abs sensors
me dad done his like danny , easy enough job and the abs rings were only a 10er
Generally, if it's an ABS sensor it'll bring the ABS light on, and not the brake warning light. If the fluid level is o.k., just check the level sensor's working, and the float's not stuck.
The fluid was fine. I changed a caliper for mot and bled the brakes then. Will order the 2 abs sensors tomorrow and looks like I might need a radiator as its sprung a leak lol
Just got home from working away so decided to throw a bucket of hot and soapy over the old shed. Comes up ok I think. Pics to follow
Looking well that pal. Proper bargain.
Needs a few bits and bobs but its a lovely drive. Drives better than any of my volvos
Comes up nice after a wash, I do like the Silver ones.
First time its been washed in well over a year. It was stood on the guys drive since 2011
