Bloody hell, with a wing that size you'll be able to carry more passengers than an airbus 380 :rolling_e
Printable View
Funny you should say that, as today's job was chopping 150mm off each end.
http://i170.photobucket.com/albums/u...530_154651.jpg
I made some temporary fiberglass brackets just so that I could get the angles correct before I transfer to alloy. and made a 'CAD' template.
http://i170.photobucket.com/albums/u...530_154602.jpg
http://i170.photobucket.com/albums/u...530_154623.jpg
Both wings now cut down, I hope to tig up the end brackets tomorrow (if work doesn't get in the way)
http://i170.photobucket.com/albums/u...531_190221.jpg
http://i170.photobucket.com/albums/u...531_190228.jpg
http://i170.photobucket.com/albums/u...531_190257.jpg
http://i170.photobucket.com/albums/u...531_190308.jpg
this is going to be so much fun when it hits the road and should corner like it's on rails, the only thing I don't like the idea of, is trying to keep up with you when we're out on a run......lol
I suspect this car won't be seeing the road in the near future, but will see some track action before too long.
Will it be possible to make it road legal,? Don't they have to be type approved or something when they have been so radically updated.
One end bracket made and fitted, but I'm running low on my stock of aluminium :)
http://i170.photobucket.com/albums/u...601_165605.jpg
http://i170.photobucket.com/albums/u...601_165615.jpg
http://i170.photobucket.com/albums/u...601_184600.jpg
http://i170.photobucket.com/albums/u...601_184609.jpg
Center Actuator support all done :) thanks once again to the front bumper reinforcement for donating more aluminium :)
http://i170.photobucket.com/albums/u...601_185629.jpg
http://i170.photobucket.com/albums/u...602_181214.jpg
http://i170.photobucket.com/albums/u...602_183656.jpg
A test of my control system for the active wing on the T-10. (you can only see it working on full screen)
https://www.youtube.com/watch?v=ZgIn...ature=youtu.be
All I've managed this weekend.
https://www.youtube.com/watch?v=k7XWyWUkBxQ
Today was a day of tidying up the wiring.
Rats nest:
http://i170.photobucket.com/albums/u...625_140104.jpg
That's better:
http://i170.photobucket.com/albums/u...625_174327.jpg
http://i170.photobucket.com/albums/u...625_174340.jpg
http://i170.photobucket.com/albums/u...622_183311.jpg
Then I bolted the roll cage down finally in readiness to make the mounting plates and final welding:
http://i170.photobucket.com/albums/u...625_140040.jpg
http://i170.photobucket.com/albums/u...625_140047.jpg
A bit of CAD design work.
http://i170.photobucket.com/albums/u...625_140230.jpg
http://i170.photobucket.com/albums/u...625_140236.jpg
Onto the cage mounts,
bent up some 3mm plate.
http://i170.photobucket.com/albums/u...627_163609.jpg
then welded it all up, and ready to weld down.
http://i170.photobucket.com/albums/u...628_170812.jpg
And the same for the rear leg.
http://i170.photobucket.com/albums/u...193505_001.jpg
http://i170.photobucket.com/albums/u...628_170615.jpg
http://i170.photobucket.com/albums/u...628_170756.jpg
http://i170.photobucket.com/albums/u...628_170831.jpg
Just need some dry weather so that I can bring the welder out and stick them to the car, then repeat for the other side.
Sounds like an absolute beast! Good work.
ooohhh the return of the whining supercharger......nice
And, at last, it's time to start on the bulkhead.
http://i170.photobucket.com/albums/u...630_175037.jpg
http://i170.photobucket.com/albums/u...112615_001.jpg
http://i170.photobucket.com/albums/u...716_152859.jpg
