Looking great keep up the good work
Printable View
Love the new lights Adrian and that Grill looks perfect mate ;)
Looks like you've got your hands full at the mo bud stripping that V70 :)
I was planning to, but thanks for the reminder Rob
Thanks Ian, the lights look ok till main beam is on, then the colours don't match, so I ordered another set for the mains. Not getting to much pressure to shift the shell, so I can take a bit of time and hopefully use or sell as much as possible
Thanks Pete loads more to do before Avon this month, got to get the car back to how she was before the last drag races
Looking good mate, but new lights and a new grille aren't going to help you go faster.;)
Nice work Ade :B_thumb:
Mr Mole, can i possibly have the ns drivers door handle, off the red one??? pretty please
[QUOTE=Nealevo;692954]Mr Mole, can i possibly have the ns drivers door handle, off the red one??? pretty please[/QUOTE
No problem Neal, pm me an addy and I'll stick it in the post
Little stumped at present as I can't work out which cambelt kit to get for the T-5R, as it appears to be on a change over period, both kits dates appear to cover the build/reg date of my car,I couldn't make head nor tail of the engine no. plate, I could just rip the engine out and count the teeth, but I wanted to get everything here ready and have one big session sorting her out for this coming seasons fun, any light on this would be welcomed, thanks Adrian
148 tooth 23mm wide belt
Part Information for "Timing Belt Kit" - 34877066
https://ci3.googleusercontent.com/pr.../348770665.jpg
Fig. Timing Belt Kit - 34877066
Attribute Value Brand CONTI/DAYCO Number of Teeth 148 Width [mm] 23
OR
143 tooth 21mm wide belt
Part Information for "Timing Belt Kit" - 34877204
https://ci4.googleusercontent.com/pr...348772045_.jpg
Fig. Timing Belt Kit - 34877204
Attribute Value Brand CONTI/DAYCO Number of Teeth 143 Width [mm] 21
Looks like the width gives you the number of teeth, 21mm wide, 143 teeth, 23mm wide 148 teeth.
Dont if it help mate give volvo me reg of my 96 on n plate for my cambelt kit but I do have an m reg engine in now tho with 23mm wide all fitted great or and got mine from volvo in Malton 80pound all in ;)
That's wot I did first in hull riverside volvo wanted over 130ish fot the kit so tuk a nice ride over on fire blade to Milton they do post tho mate
do you have a contact no. for them mate ?? I tried messaging Rufe but got no reply so was looking for an alternative supplier, if I can fit a volvo one at a decent price then I will, but got to keep some pennies back for a new fuel pump, as I don't believe the one I pinched out of the 2.0litre is really up the the job and worry that it's not fueling fully at wot, so a bit to do this week.
I rung rufe a few times no answer tho pm sent your way mate
Slow progress I know, but she's in the workshop and dis-assembly is under way
http://i1290.photobucket.com/albums/...ps394429da.jpg
Whilst under the car I found this little unit, only had the car nearly 7 years and not noticed it before, what is it ? a vacuum pump or something similar ? should there be pipes to all ports ? and could this lack of piping cause my lacking boost ?
http://i1290.photobucket.com/albums/...psff24f7ec.jpg
Looks like I'll have to copy Oblark and knock up some nice brass bushes for the linkages, as I had to get a tad heavy handed with the one linkage
http://i1290.photobucket.com/albums/...ps0c6e889d.jpg
and the others are queuing for attention ... lol
http://i1290.photobucket.com/albums/...psf21d19cc.jpg
http://i1290.photobucket.com/albums/...ps753aeff4.jpg
Isn't that the evap purge canister?
And what's with the MG up in the rafters? I've heard of shelving a project but that's taking it a bit far lol.
Its for your cruise control, and yes, one port should be open, it confused me when I saw it.
Only reason I know this, because I moved my as it was in the way of the lower intercooler pipe!
