Noooooo not a honda now there's a car with no torque.
Printable View
:hilariousguess I nicked a tad more weight loss on mine then mate.........but tripping back to Jardons other comment about vehicle weight loss due to loosing MOI on the transmission drive train, mine works out depending on the wheel tyre radius of a total vehicle weight loss in first gear using a standard T5 box of between 40 and 48 kg not bad from just a flywheel change in second gear its a lot lower 15 to 20 kg.
But there is more to the drive train than just the flywheel plus any weight saved here is still taken away from the total vehicle weight...........nothing really new here then :slap:
:wizardtro flywheels store inertia which may help your granny not stall her Fiesta going to Tesco's but won't help you to obtain max power period.
3.6 kg option wasn't around 2 years ago Ped.......................just make sure you don't disapear like the Wizard when you do get out on track.... ;)
