Severe Rumble when Turning Right
Hi guys,
I've got a servre rumble when turning right, the car vibrates you can feel it a lot in the clutch pedal. I have replaced all the engine mounts except for the hydraulic ones. 2 of the 3 were shot, I have also replaced the wishbone on the left which was almost gone. The problem has got a little bit better but still remains
It gets worse when slowing down from speed, don't think its the wheel bearing as I'm unable to rock the wheels. Ive tried disconnecting the abs, the car got a lot more jerky and revs dropped quicker but the problem remained
I've run out of ideas now, going to refurb the rear brakes at the weekend as the car does slip and knock a little when using my handbrake on sharp hills. Worth a shot
Can anyone advise? thanks in advance
Will,
