im having a problem with my locking, basically sometimes both offside doors will not unlock.
its something to do with the deadlocking, as i cant open it from inside either.
nearside doors work fine, anyone got any ideas what to check??
cheers
Printable View
cheers
hi mate had same prob with mine on monday just drivers rear door had to take door card off and sprayed wd40 on the solinoid linkage and sprayed all the door locks seems fine so far hope this helps
I had the same on my 855. Ended up stripping the door and fitting a new electric motor lock. Salvo had the parts, came to 25 quid or thereabouts (plus any labour if not DIY)
ive fitted a new frt door motor, doesnt seem to of done the trick.
did you have just the one door not unlocking, or two doors like me?
cheers
